Refinish headliner?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Man rebuilding a truck is a slow project lol
I'm just now getting close enough that I can start to tackle the headliner. However, I'm not sure what color fabric to order. It's Gray if that means anything. I see GmPartsDirect only has one part number for the entire headliner so assuming they are all the same color?
If you go to www.stockingeriors.com you can order samples first if you’re trying to match it up.
ivin74
05 NBS Nali
Htown, Texas
Yes it is, I thought you would have the headliner done by now.
super helpful. i just ordered a set of free samples :)
Sent from my SM-A505U using Tapatalk
It’s a great company to deal with. I used carpet samples to match up with the bottom of the door panels, the sides of the console and the backs of the fold-down second row seating on my 02 Denali, all of those have carpet too. They sell good stuff.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
me too lol my paint job changed from a 1 month project to going onto 7
+ now lol but pillar trim isbpulled right now so headliner will pull right out :)
Before you spray the board--after removing the old headliner material--use a stiff brush to get all the old foam off. Whatever you don't will show through, or cause it to not adhere well. When you're all set, spray both the board and then the material. Let them tack up, then stick them together. There's no do overs, so make sure it's where you want it to be with no wrinkles. If you get a wrinkle, you won't be able to pull that section off to redo it. The foam will come off, then you're screwed. Do small sections at a time--don't do more/larger areas then you can handle. I like to use a plastic bondo spreader to smooth it out as I'm laying the material down--with it glued--. Sometimes it's better to have a friend help you out, especially with such a big headliner.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Awesome tip with plastic bondo spreader. I like idea of doing sections at a time. Then I don't have to worry as much about running out as I can go to store and get more then :)
mountie
What Tonyrodz said........ :)
Another thought........When I wanted to re-do the headliner in my old truck,.... after I took the headliner board out, .... I decided to take the board to my local upholstery shop and have the experts do it.
I got it back later that day , costing $65. Including the adhesive & fabric.
( I was too chicken to glue the fabric myself, since it was so cheap to have them do it)
That's an awesome price!!
dizhai
