Mini d2s retrofit
mcislak
Looking for some input from guys who have done retrofits with hids. Ordered new housings and the morimoto mini d2s 5.0 Apollo 3.0 shrouds and a 55 watt kit all from the retrofit source. Got everything installed just fine but when I fire the lights up my drivers side works but my passenger fails to ignite. Tried swapping bulbs ballast igniters different relays everything. Same results. I have my drl disabled. Am I missing something
K2 Kaiju
The Depths
Bulb out? I remember a retrofit I did years ago and the wire were backwards and you had to put put plug upside down...
Sent from my SM-T580 using Tapatalk
mcislak
mcislak
Bulbs are good. I think I might of figured it out. I turned off the approach lighting through my DIC and all has been working since
91RS
GA
What headlamps did you buy? Do you have any more pictures? I'd like to see how you attach the projector to the stock reflector. I'm looking at the same kit from Retrofit source. Thanks.
HACK BLOCK
NYC
how were u able to get off the orange reflector? I was trying to take it off but felt like I was gonna break it
mcislak
mcislak
On the back side of the orange reflector there is three or so tabs that I cut off and it came right off.
mcislak
mcislak
I just amazon searched for Yukon headlights. I believe the brand was eagle eyes
HACK BLOCK
NYC
ok I didn't know if I should have cut it or not
HACK BLOCK
NYC
eBay has them cheaper and came faster than Amazon suggested I would get mine
91RS
GA
I was going to check eBay when I get a chance. I couldn’t find the Eagle Eyes brand on Amazon when I looked yesterday. That brand name sounds familiar so I think I’ve had something from them in the past. The “insurance quality” brands like TYC and Depo I’ve had bad luck with in the past of not lasting very long before they look like garbage again. I was planning on buying new GM lights for this but my preliminary research into this found that it’s very difficult to get the GM lights apart due the sealer they use so I don’t want to risk damaging brand new lights.
91RS
GA
I'm going to ask this here first since you used the D2S 5.0 like I am. Did you use the rubber "gasket" between the projector and the reflector? I bought the tool to tighten the lock rings with and I've tightened it to the point where I'm scared to go much more and the projector can still be wiggled a little bit so I'm nervous that they'll move after hitting bumps in the road. They seemed to be more sturdy without the seal but I still fear that once big bump and it'll move and then the nut will be loose. I didn't grind down the lip on the reflector side because it doesn't look like the reflector is even on all sides so I wondered if that would cause problems also or weaken the plastic too much. I thought about taking the seal out and putting epoxy or something to attach the projector to the reflector another way once I get the beam level but if that doesn't work there'll be a huge mess left behind.
mcislak
mcislak
I did use the rubber seal between the reflector and the projector. They included it in the kit so I figured best to use it. As far as getting it tight I cranked it down pretty good and haven’t had any issues of it loosening and twisting
91RS
GA
Maybe I just need to crank down on it more. I’ve got it pretty darn tight right now, at least I think I do, and I can still twist the projector a little. I feel like putting in the bulb and igniter might move it.
I attached a picture of the lip inside the reflector I was asking if you ground flush or if you left this one alone.
curbud
