Alright so you're lean on that side for some reason, O2 sensor is not getting as hot as the other side.
So what can cause this? Leaks, cracks, crimps, air, fuel, shorts to ground? Fuel getting to both sides of the rail evenly? No pipes crushed? Injectors good and nothing falling off them or has fallen into the hole they drop into? Intake gasket good, no cracks or leaks on that side, head gasket, intake gasket, intake manifold, cylinder head? Plugs screwed in all the way and firing? Not stripped and leaking? Rockers, valve seals...
