HiHoeSilver
Away!
Chicago
I don't want my vehicles to be loud, i just like them to make noises. I might be a child inside. My catalytic converters are borderline and i'll get a P0420 every couple weeks so those will prob get deleted and I'll disable that CEL code with a tuner. I'm still on stock exhaust so I'm hoping it will get ever so slightly louder but more... I'm not sure... bubbly sounding?
Will definitely be louder.
R3cord303
Posse In Effect
Oregon Valley
Hopefully just the right amount. I haven't been able to find a clip of an NNBS with just a cat delete. Tons of videos on long tubes and aftermarket exhausts, but not just a cat delete. Paying the local muffler shop to cut the cats out and replace with a section of stainless pipe is way cheaper than buying replacement cats so that's the route I'm going to take. Just lame that the exhaust is gonna smell real bad afterward.
BG1988
just get a replacement it's cheap that is the correct one
AP Exhaust Holdings 740566 CARB certified 50 states
CARB Executive order D798
it should cost 40$ or so at a muffler shop to put it in..
https://www.horsepowerfreaks.com/-p-152502297.html?gclid=CKyS-9at2OICFfQgrQYdy_8ACw
Dont let the shop keep the scrap converters they are worth 300-400$ for both on ebay you will be able to recover about 30-40% of your money back
HiHoeSilver
Away!
Chicago
@kbuskill?
R3cord303
Posse In Effect
Oregon Valley
I would- or I could just pay the shop 1hr of labor to put a pipe section in. That's $600 for a set of converters. If we had inspections and testing here I would totally put a replacement pair in.
BG1988
what about everyone else that likes to breathe
BG1988
The converters are already bad so it wouldn't make a difference homie
i would check for an exhaust leak normally the 420 code is solid and stays put if you get it ( sometimes 420 and 430 is a secondary code as well for the MAF or map sensor)
it just does not come on and off so it's still working at 99% and sometimes dropping to 98% and back...
also see what temperature it's coming upto using a live data code reader if it's over 500-550F or higher
then they are working..' and you have a leak or broken sensor..
550-560F is typical for the Tahoe..(i'll confirm tomorrow since i will have a long trip )
R3cord303
Posse In Effect
Oregon Valley
Naw see you're not understanding- I don't have an exhaust leak. It goes away because I keep clearing it. I'll buy a Tesla in a few years to make up for my carbon footprint.
Ridin Solo
Brain Ninja
Well, it’s not much... but I got bored and decided I would finally take the badges off the rear hatch before I give him a bath [emoji41] I put this off for years just out of pure laziness but glad I finally followed through.
carman2197
