Hi-psi
Atlanta, GA
Got around to putting on the McGaughy's 2/3 drop today.
Stock
When I had a McGaughy's rear 1.5-2 drop only to level it.
Full McGaughy's 2/3
Ouch, where's the dislike button!
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I just hope I can find a real nice used one, it's AWD so it has to be a pretty close match this set only has 9k on them
*maybe I can just put a new one on? not sure how much these have worn so far
St. Louis
What make/model tire was it?
Also, what happened, did it just blow?
2001 Yukon SLT
2001 Yukon SLT
goodyear eagle ls/2 there pretty good tires (imo), I apparently had a big nail/screw or something in it (which then came out leaving a big hole), tpms alert came on at about 85-90mph, but where I was traveling it is nothing but wall no place to pull over safely so I just went ahead about 3/4 of a mile to the next exit, I wasn't going to stop on the freeway there it's a pretty bad place to stop. wasn't a blow out I found the big hole in the middle of the tread probably about the size a 16p nail, I think I made it just in time no rim damage
at least it was only about 90deg out, not freezing cold rain and wind last time I had a flat, lug nuts came off without having to burst a hernia, can't complain too much
Prolly just driving on 3 tires until you came to a stop.
ya I don't know far the tpms light was on, we just went to see Godzilla and the drive home is about 8-10 miles, I saw it on about 2/3's of the way home and thought maybe it's just a slow leak at first till the rear started to lean and then I had to keep going to the exit
Phlipnstik
