kbuskill
NE. FL.
I ordered a Nokia DT-900 Wireless charger.
I chose this charger because it has 3 coils and runs directly off of 12V so there is no adapter or USB port needed to install it. It also does not use any power while there is no device laying on it, so no worries of it getting to hot or draining the battery on the Burb while it's not being used.
I installed it in the center console lid and wired it directly to the back of the rear cigarette lighter port in the console.
Only took this one pic with the rubber off so you can see it.
The hole isn't perfect as I couldn't find the proper cutting tool for my "dremel".
I also cleaned the crud off of it before reinstalling the rubber mat... didn't realize that crud was there until I removed the mat... its amazing what hides beneath... lol
Anyone here installed this yet? ive got the Alpine X009GM looks amazing on the dash but the software is pretty outdated and boring thinking about trying this.
https://www.phoenixautomotiveinc.co...roid-navigation-radio-for-gmc-yukon-2007-2014
I don't think any members have but it was mentioned recently and there was a video review for it on another truck a ford I think but one of the caveats is the hvac will not come on until you manually turn it on once the system has booted each time, unless that has been resolved that would be a major no thanks for me.
Get one of the new units from someone like Pioneer that have wireless Apple Carplay or wireless Android Auto. I just bought one and it’s amazing. Combine it with a Maestro module and you can display and control lots of your vehicle controls through the OBD. I wouldn’t turn over my cars HVAC controls to something like that. What happens if that unit has a problem? You lose entertainment plus heat and ac?
Just noticed today that the passenger side rear window switch doesn't put the window up (puts it down fine) ..... Lol.
My daughter had the window down but couldn't put it up. The drivers switch put it up fine. Guess it's a bad switch??
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I found out yesterday during the trip home that the left rear window of mine did the same. I worked the switch roughly up and down while wiggling until it worked again. It's probably dirty/slightly corroded contacts from lack of use. Regular use of switches keeps the contacts clean. I may take it apart and clean them with some electrical contact cleaner.
St. Louis
After reading this today, I popped the switch out, unplugged it and removed it from the trim housing, then opened it up and sprayed electrical contact cleaner in it. Then put it back together and plugged it in and it's working fine, both up and down!
Thanks for the tip!
2001 Yukon SLT
Thanks, we appreciate that. I just wanted to make sure you knew we have the phone support, if anyone needs it.
I Bought this autocal used, I have downloaded your software, can I delete these old 2014 files from the previous owner or format the data? so I can connect it to my truck and get the files you guys need.
jsoltren
Cabin air filter! Dorman 259-201 cabin air filter retrofit kit. I removed the trim panel on the passenger side of the center console (two metal clips and one plastic clip) and the passenger kick plate (three screws). Then I cut the panel cover using a utility knife since I couldn't get my dremel in there. It took about an hour, and about 80 passes with the knife to slice through.
https://www.amazon.com/dp/B00NF1SK1M/
Some people use this as an opportunity to wash and flush the radiator that's right there. I didn't bother.
does anybody have the part number for the febreeze scented cabin air filter, i guess it's fresh breeze
Nvm found it: Cabin Air Filter-Freshbeeze Fram CF11809
Those are made by FRAM. ACDelco with carbon is CF193C.
I think I have the carbon one installed, I'm going to try the fram one with arm & hammer, I thought there was a febreeze scented one but I think it was just the deceptive fram advertising on the package
kbuskill
NE. FL.
You should send me the carbon one your not using... oh and the cover too, I'll need the cover.... lol
I will check tomorrow when the febreeze one comes if it's still in usable condition you can have it, you can get the door/cover off ebay pretty cheap
ASG-MikeS
