Man am I happy I don't have the tpms setup!so I bought this little cheapy tpms tool that James mentioned because I thought that the 2012 tpms procedure required a special tool, however after screwing around for a bit with the tech2 and not finding any method to reset the tpms, I googled and found that all you have to do on the 2012 is turn the key to run, and hold both the lock/unlock buttons down on the oem keyfob and walla 5 seconds later your in tpms learn mode, then you can inflate/deflate the tire for 8 seconds or use the little tool (which worked fine). just hold it on the tire near the valve stem while holding the transmit button until the horn chirps once, working your way around clockwise starting at the left front.
it took a whole 1-2 minutes once I figured it out, lolMan am I happy I don't have the tpms setup!
It's just more electrical crap to have to worry about, or break.it took a whole 1-2 minutes once I figured it out, lol
it says's it is for GM but who know's with china stuff they may have the same tool rebadged for other vehicles to increase salesYup that what i do on my 2010 but i use the one at work haha.
Is that tool universal for tpms or just gm
ahh so you are the 1% that can do that...When I get bored I polish my knob...
I bought me a camper on tuesday afternoon, so I took every bit of power that this goddamn suburban has in it, and brought it home (from storage) to work on.
I had to buy for my 13 inflate deflate doesn’t work. Been using that since bought the hoe in 13 easy peasyso I bought this little cheapy tpms tool that James mentioned because I thought that the 2012 tpms procedure required a special tool, however after screwing around for a bit with the tech2 and not finding any method to reset the tpms, I googled and found that all you have to do on the 2012 is turn the key to run, and hold both the lock/unlock buttons down on the oem keyfob and walla 5 seconds later your in tpms learn mode, then you can inflate/deflate the tire for 8 seconds or use the little tool (which worked fine). just hold it on the tire near the valve stem while holding the transmit button until the horn chirps once, working your way around clockwise starting at the left front.
Thats f’in great......I would have laughed my ass off if i saw you on any highway around here.... a 2500 pulling that little thing.... you should have put it insideI bought me a camper on tuesday afternoon, so I took every bit of power that this goddamn suburban has in it, and brought it home (from storage) to work on.
I like them. They have a Fiske FM5 look. We shall dub they "Fikse FM6's".
I didn't try the 8 second part just used the toolI had to buy for my 13 inflate deflate doesn’t work. Been using that since bought the hoe in 13 easy peasy
I didn't try the inflate/deflate method just read that it could be done that way but it didn't give specific years so it obviously doesn't apply in this case I was more concerned about getting it into the learn function. I had also read that tpms learn was under special functions but all that was there was a keyfob button test, so I just went out and checked again turns out it is under rcdlr-module setupThat's weird that letting the air out works on yours as it was supposedly discontinued after 2009 and required the tool.
In the special functions section of the Tech-2 in the RCDLR module, you can use the Tech-2 to activate the TPMS relearn for use with the tool only.
