You're not wrong and neither am I, the boxes can be labeled differently.
Looking great. Are these OEM? Who’s the manufacturer?
Something doesn't add up here, either you are wrong or my fuse box labels are messed up. My #66 is WSW/HTR - Windshield Washer Solvent Heater (60A) which does't have a fuse in and #71 is LGM - Lift Gate Motor (30A) don't think either of them have anything to do with TBC
The way you have it is the way it goes. Different years may have changed. Easy to tell , grab your dvom and hit the rear trailer connector... if you got power, done.View attachment 216789
Max tow pkg comes with jcase fuse but you still have to hook up the battery charge wire if you want charging in the rearI didn't have to add a fuse on my 2012, hooked them up and they worked
that's what got me confused plus I came across the picture that Pete posted, but like he said "Different years may have changed" so in my case no need to add fuse and fender wire goes to the left post and wire closer to the engine goes to right post closer to the fender criss cross.I didn't have to add a fuse on my 2012, hooked them up and they worked
Beautiful, just beautiful...
They are made in Taiwan Eagle EyesLooking great. Are these OEM? Who’s the manufacturer?
Sent from my iPhone using TapaBlah
Edit: im being my normal wiseass self fyi....![]()
Now if this PA winter would figure itself out I might get it cleaned up!Looks good!![]()
Went catless today...
I'm not convinced that I like it. It is louder and definitely has more growl/rasp than it did before.
I think I will probably drive it for a few days and see but most likely gonna get a resonator or something to tone it down a bit.
I honestly didn't expect it to make that big of a difference in sound.
Jersey has visual cat inspection that sucks, btw your tahoe sounds great without it!
Sent from my Pixel 2 using Tapatalk
Less backpressure in the exhaust will usually move the powerband up in rpmThanks.
It doesn't sound bad. It's just more mud truck less, luxury truck sounding.
I was content with the exhaust tone before and didn't think the cats would make that big of a difference.
I also feel like it lost some bottom end torque but that may just be because it makes more noise than before so in my mind I think it should be going faster... lol
