Koala's 05 Tahoe
haven't had a lot of time to work on truck but I did get a center console for my truck, order some wire, and supplies so I can work on replacing bottom cubby with a single din. Once I have that moved I can work on installing the Android Auto, Rpi3 computer. slowly but surely getting there
Pretty sure that console has a Bose sub and amp in it.
KookyKoala
KookyKoala
somewhere, IA
haha yes the console has the sub and amp I need to get them stripped out.
As for write up, i am using Crankshaft-NG project as a base there are write ups on installing the software on the pi, the full car integration been a little more tricky few YouTube videos and time checking there reddit I was able to build that black control box it has a timer curcit, relays and a couple of step down converters.
I wanna get it installed and working in my tahoe before before I try and do a write up for how I did it :boti:
You lost me at "as for write up"lol. I think my eyes just glazed over :shakehead:
KookyKoala
KookyKoala
somewhere, IA
LOL, Well Ive made more progress on my stereo this morning got my 80PRS unboxed and started modifying center console to fit the single din stereo. there is a small gap on the passenger side that the ill need to figure out but it looks pretty damn good so far
Here are the results, i need to make a couple of extension cables for the stereo and i will be ready for a test fit in the truck
KookyKoala
KookyKoala
somewhere, IA
finished up my prep work for install extensions have been made for stereo harness and loomed up. it was 5 degrees high today couldn't drag myself to the garage to start install plus still waiting on glove box assembly to show up.
Hopefully tomarrow after work I can put it in use my work garage :) its heated
KookyKoala
KookyKoala
somewhere, IA
Well, I went to put the center console in today however. Aparently you need a e16 deep well for seats.
KookyKoala
KookyKoala
somewhere, IA
I know my amazon stuff gets here eairly, my glove box is a day late due to local usps closed due to -50 degree temps, but cubby didnt show up -.- oh well not like consoles in truck yet
KookyKoala
KookyKoala
somewhere, IA
Well today has been productive and busy I got my center console installed, stereo moved down and ready to get the car computer installed fought with seat bolts more I found that it wasn't even an e16 for the front they are e20's however a 15mm worked to get the bolts out
Bench seat is pulled
After a good vacuum I got the console in and bolted down.. I did have to snag the harness from my glove box assembly to get the front two 12 volt ports working
Hopefully tomarrow I will get some time to get the car PC put in but I am all prepped to get it installed :)
Oh and I ended up flipping the cubby because I didnt have the rubber piece for the bottom
View attachment 215514 View attachment 215513
You just need 16 pt sockets for the seat bolts. Good work.
KookyKoala
KookyKoala
somewhere, IA
[QUOTE
Oh and I ended up flipping the cubby because I didnt have the rubber piece for the bottom[/QUOTE]
Damn Tonyrodz ;)
I didn't have my 12 points with me suprising my 6 point was able to get it done.
Haha thanks next I think something's gotta go in that hole in the dash :D
Oh yeah 12 point lol. I can’t find my 16 points either.
KookyKoala
KookyKoala
somewhere, IA
WhooooHoooo!!!!! :boti: it has its test fit in and is up and running =) I only fought the simplistic most task in installing I set up all my relays for positive trigger forgot to test at the bcm it is a negitive trigger for the headlights it's ok I set my night mode to run of the time for now.
KookyKoala
KookyKoala
somewhere, IA
Nice work.
Thanks man, been collecting parts and bench testing for about a year now before getting it in
If only someone sold retrofit kits like this :emotions33: .
Would be popular, especially for 99-06 trucks.
Haha yeah, it's actually just a double din kit with the official RasberryPi Touchscreen Glued into it. LOL
Towmaster
