bfourman
Indiana
Drove it to pick up a couple of items from Bloomfield Manufacturing Company, makers of the HiLift jack. Had to take the obligatory pic with the giant jack.
My other ride that I use the HiLift for...
sarneson91
Alexandria, VA
Just recognized a squeak in my front suspension from my post cross country drive, rinsed everything off sprayed some corrosion block on the LCA's, anyone have any other thoughts on what it could be. Have a feeling I might need to replace my struts soon anyways since im at 190k on the tahoe and don't think they've ever been changed.
BourbonNcigars
Got a short road trip coming up and can't take it with a dirty hoe. Gave it a wash this afternoon. Also installed a dual USB in the back of the center console. Taking my daughter and one of her friends out of town for her 15th birthday. Figured two teen girls will need phone power. Also got some custom made foam to put in the back. Working for a company that manufactures polyurethane foam has its advantages sometimes. Had someone cut three pieces for me that will lay out flat for a bed with the back seats down. The third piece of foam fills in the "hole" when you tumble the seats forward. When not in use, they all fold up neatly in the cargo area. Splurged and spent $15 a Dollar General for a blanket that was just the right size to tuck around the foam.
bigrhino
l.e.s manhattan,nyc
at the little black interface box on the drivers side floor just above your left foot, the black cover just pops off and there is a lead there for the dome lights, I patched the puddle lights to that and some led strips under the dash and the ones in the grill. my puddle lights do not light from my aftermarket alarm but my dome lights will so I just patched them all together
I have an aftermarket alarm also. How did you hook up the puddle lights. Wiring etc.
Hi-psi
Atlanta, GA
Installed a flash logic remote start. 4 plugs and no wire splicing. Well worth the $120
Even though I have factory remote start, I've been thinking of buying/installing it as well.
As I understand, it will also work as an "add on" so to speak for the pre-existing factory remote start and let you use their smartphone app to remote start from anywhere. I know you can get that functionality with the GM/OnStar app, but I have an updated VCIM from a newer vehicle in my '08 to add phone Bluetooth ability so no OnStar for me. I live in an apartment complex and sometimes I'm not lucky enough to snag a parking spot close enough to the building for the remote start with the keyfob to work from inside my apt.
Ilikemtb999
Denver
Only downside is I don’t know how to get the car link. Nobody appears to sell it and there’s no app in the Apple store.
Had a sticky seat belt receiver, actually it wouldn't grap the clip unless you jammed it in there a few rimes, wanted use something that might last longer than wd40 thought I had a can of graphite lubricant but some good ol tri-flow worked like magic, now it's like throwing a hot dog down a hallway, goes right in
had to pull the headlights out again today to put in some new kensun 55w digital ballast, the ballast's I put in two weeks ago were crap I guess, one flat out died in about 5 days and the other one was intermittent, luckily i have the headlight removal down to an art, lol
Ridin Solo
Brain Ninja
Not very exciting but finally put the weather tech floor mats in that I bought. Debating on if I should buy the one for the trunk as well. Also, starting to hear some engine knock on cold start ups
briannorris
