2005 Yukon XL - Puddle Light lens part 2 ... CLEAR!!
Sam Harris
HiHoeSilver
Away!
Chicago
Thanks! That would be great!
Here you go.
HiHoeSilver
Away!
Chicago
Wow! That is bright! I think more than I’m looking for. Maybe just the reflection off the white paint. I do like how well they light the ground.. Appreciate the pictures much!
Yeah, the camera picks up that hot spot like crazy, not quite like that in person.
mountie
mountie
Now, that's what I am talking about!!
I am researching an additional flush-mounted led strip, mounted on the bottom of the door panels, and using the lower courtesy light power on lower inside panel .... Light the ground when doors are opened.
05Single
afraid of the dark
Yea that's the only thing, once you open the door the light leaves with it leaving a dark shadow on the ground. Then technically having no light for seeing puddles lol.
mountie
mountie
Well, when you open the door, the interior lights turn on, and stay on as long as the door is open.
Including that silly white/red lens light on the inside lower door panel.
I want to put an LED strip at the underneath - door panel, aiming light below the door while it's open.
And the light stays on as long as the door is open ( Really illuminating the step & ground) ... not like the puddle light that goes off in 15 seconds, and only when you hit 'unlock'.
I'll jump power from that white/red lens, only inches from the new light strip.
73impala
Margate, FL
Different car but same concept can do with a flush mount led or if you want the logo can do the same. I drilled a hole in the bottom and ran the wires to ones that came on with the interior.
1937078_10153211145817793_3793641599719946622_n by James Pate, on Flickr
What I used is called anything from puddle lamp, door projector, ghost shadow, or any combination of the three on ebay.
This is what it looks like before install, even comes with the proper whole saw. There are tons of different color variations that you can get if you wanted the Chevrolet logo or any other logo.
Or you could do something like this (which I used for puddle lamps in my non tow mirrors for my silverado)
It's a flush mount eagle eye.
https://www.oznium.com/led-bolts-prewired-leds/led-bolt
HiHoeSilver
Away!
Chicago
There is a thread on here somewhere with this mod.
mountie
mountie
HiHo .. ( LED strip under door panel )....
I found it's not that easy to "find that thread".... Unless you know the exact key words.
But I am interested to find that thread!
HiHoeSilver
Away!
Chicago
I can try when I have a few minutes. It might be in the show off your exterior lighting mods thread. Or @05Single might remember....
Drewphil
