- Joined
- May 9, 2018
- Posts
- 7,155
- Reaction score
- 13,953
Thanks, guys!!
Do you have any night shots of these? Curious about them, but not sure I wanna go THAT bright.I used these. They are a bit wide, so I put them in on an angle, and they turned out exactly parallel to the ground.
They are pretty frigging bright.
4Pcs 800 Lumens Super Bright 42mm... https://www.amazon.com/dp/B078MLRNCX?ref=ppx_pop_mob_ap_share
Thanks! That would be great!I don't, but I can tonight.
Wow! That is bright! I think more than I’m looking for. Maybe just the reflection off the white paint. I do like how well they light the ground.. Appreciate the pictures much!
Yea that's the only thing, once you open the door the light leaves with it leaving a dark shadow on the ground. Then technically having no light for seeing puddles lol.Now, that's what I am talking about!!
I am researching an additional flush-mounted led strip, mounted on the bottom of the door panels, and using the lower courtesy light power on lower inside panel .... Light the ground when doors are opened.
Well, when you open the door, the interior lights turn on, and stay on as long as the door is open.
Including that silly white/red lens light on the inside lower door panel.
I want to put an LED strip at the underneath - door panel, aiming light below the door while it's open.
And the light stays on as long as the door is open ( Really illuminating the step & ground) ... not like the puddle light that goes off in 15 seconds, and only when you hit 'unlock'.
I'll jump power from that white/red lens, only inches from the new light strip.
More I look at these, the more I want to polish my puddle lights, and put those in. [emoji16]
HiHo .. ( LED strip under door panel )....
I found it's not that easy to "find that thread".... Unless you know the exact key words.
But I am interested to find that thread!
