You get 2 10 minute auto starts then you have to key start it to reset the auto starts. I have not found a way/method/ anyone to extend it. Maybe someone with a Tech2 can chime in.
Sent from my SM-N950U using Tapatalk
I think the 10 minute thing is directly related to the bcm, everything is timed to 10 minutes, security functions, leaving the radio on, headlights on, interior lights etc, all on a 10 minute timer, even my aftermarket viper smartstart still only runs 10 minutes
St. Louis
I know it's limited to 2 (20mins total) and thought you could use a remote button to add the additional 10min cycle while it was running on the first cycle, but when I hit the start button while it's running it shuts off. I'm sure I'm doing it wrong
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
So after SOMEONE posted they got cheap floor liners, I was doing some research and found the Husky Weatherbeater on sale for $40.19 because of a damaged box. Floor liners were fine.
I like these because they don't go up on the sides as much, especially because the weathertechs were falling down.
I noticed in these pics the color is almost blue, but it's deep grey and doesn't look as bad in person.
how are those husky's working out now that it's a been a month or two, are they deforming or doing anything weird?
93blkongreenpro
2001 Yukon SLT
The 1st cycle will complete its run and auto shut off. I then hit lock 1 time and restart for my 2nd 10 minute run. I dont think you can "extend" the run, only end auto start, and start the 2nd autostart cycle. So there will be an interruption between cycles.
NathanJax
Vacation Nathan
Jax, Fl
Fine, easy to clean and stay in place. I’m sure my old weather techs were ok, but they were just old, dirty and drooping.
I would 100% buy them again or buy them for another vehicle
***Warning!*** I'm about to blow y'all's minds with an incredible solution that's free and easy and you can do it with the knowledge and equipment you already possess:
If you put the key in the ignition and turn it to the "on" position while it's running, it'll stay running until it's out of gas, giving you plenty of time to clear the snow off and from around it. You're welcome.
M3kanic
When I was stationed at Ft. Drum it would get down to -40 something and the doors would freeze shut so I couldn't open my doors until they thawed out. And I also tried different grease products to try and stop it but with wind chill being close to -100 not much does not freeze.
St. Louis
Unless you live in the hood!
When you get done and go back inside for a few minutes to gather your things to leave and you come out and someone jacked your car... Lol
2001 Yukon SLT
gpracer1
Phoenix
No more stabbing the go pedal for a bit.....popped a motor mount on the way home tonight.
Anyone have the hummer part number handy?......gonna order tonight.
gpracer1
Phoenix
ASG-MikeS
