Yep. Still getting used to skating it on the freeway. It takes practice. I will eventually replace the air management system and get something that will maintain a set height front and back. The rear is hard to judge because the psi diff is small when adjusting height. 35 lbs to 40 lbs is a few inches diff where in the front it’s more like 120 to 160 is a few inches diff. I was rollin along thinking the rear is level with the front but obviously it was lower otherwise the rocker would have never hit.Sucks about bottoming out![]()
