Question for the 01-06 people
Cliffjrs
I bought with 136,000. I'm at about 186,000 now. Tuned at about 183,000 and never drove better.
My 2001 5.3 Tahoe has 241,000 plus and still running strong, no smoke, no oil usage etc. But, I’ve probably replaced every GD sensor and some more than once!
jlp78
I bought my '05 Yukon with 205k on it. I had them replace the steering box (was leaking at the pitman arm) and the alternator (had an annoying whine). The only thing I have had to do is swap out the transfer case control motor (there was a remanufactured one on there, so it had apparently failed once before... replaced it with a new Dorman part). The thing is a beast and rides like a dream.
adriver
I have a 2002 Silverado with a 4.8 and a 5spd MT. It has intake, exhaust, and tune. I drive it harder than you ever will with an automatic unless you are always towing or like donuts. Once warmed up, I near floor it through first and second up to 6k rpm almost every time, and through third if getting on the highway, then shift up to 5th real quick to cruise. I bought this with 90K from the original older man owner 7 yrs ago and now have 234K miles. I keep up with basic maintenance, and have never had a problem. I recently had it smogged and its near the same as it was 6 yrs ago, something like 1928 to 1938 ppm. I have been thrilled with its reliability, and here researching for when I am ready to start a GMT820 with a Man(ual) trans.
I'm going to assume you read the sticky at the top of the forum, that lists most of the model problems, there isn't anything that is overly troublesome. With the engine the biggest KNOWN problem is the Castech heads.
To take it farther:
Doesn't sound like you are an OEM is always best person, do you do your own maintenance?
RWD/4WD/AWD? 4WD can make some maintenance a little more time consuming, but nothing to be afraid of. AWD TC can have some problems.
I came over from BMW after wanting another pickup. They get high marks for reliability, but they are almost disgusting to own. My pickup's cooling maintenance is to change the coolant every year. My BMW's MANUFACTURER REQUIRED maintenance schedule is to replace the entire cooling system (radiator, waterpump, hoses, sensors, and "must only use" $30 a gallon "BMW" coolant), EVERY TWO YEARS.... That's the kind of BS they have you do so they get higher reliability ratings, you replace everything before it breaks. I'm even talking about the older models that were these same years. They want you to spend $4-$6K a year in preemptive maintenance. Not only will I never go back, but I am planning on getting an SUV and my pickup to last me for as long as I can think of. With BMW I picked up the mindset that any vehicle needed to be <100K miles on it. After owning my pickup, and everything I have read on several forums, when I am ready to pick up another vehicle, its going to be: Well maintained, up to 250K is no problem.
I really don't think a well-maintained LS GenIII/GenIV engine seems to have a limited life span. I know you don't want to get one, but if something does go wrong: a lot of it is easily interchangeable, theres a world of knowledge to help, you can find low mileage engines and trans for cheap everywhere, there is nothing overly complicated or that requires expensive/specific tools to fix. The 4.8 is the same as the 5.3 outside the short block.
Cyclemoe
I bought my ‘06 2500 Sub with 190k 2 1/2 years ago. Have 220k on it now and couldn’t be happier.
drakon543
drakon543
no adriver i dont always go oem only when its basic stuff like sensors and other parts like that. my stock manifolds were pretty wooped so i went with headers. muffler was showing signs so i built a cat back setup. wife warps rotors like its her job so i usually upgrade that. everything else i upgrade is generally for mpg or more features.
KatGV
Nuevo,Ca 92567
My 05 4x4 is a daily driver AND the family Az trip vehicle (sometimes monthly if not more often we add another 600 mile trip) it gets driven hard, 208,000 engine was noisey we elected to replace, 245,000 or so trany went, and 270,000 or so the transfer case .... it's always serviced at the dealer my hubby works there. AND yes it depends on how it taken care of, but now my baby's is like new and will hopfully get another 200,000 miles at least out of her. (cfrossing fingers) good luck in your search.
i currently have my 97 Tahoe and my wife and i have been debating on moving to the next year model. yukon, tahoe, Escalade whatever i happened to come across that i like. my only real question would be at what mileage would you guys say nope if you were looking? regardless of price lets just go with seller says everything is fully functional and well maintained. i would rather spend my time going to test drive and look over a truck that i can have a better chance of it being dependable. aside from basic possible regular maintenance items at what point are the 01-06 prone to have the engine or transmission ready to go just from normsl wear and tear. i keep hearing this model range goes forever and i dont want to start off with a possible project on my hands.
mountie
I bought my 2005 Yukon XL SLT about 6 months ago. with 140,000. One owner, dealer maintained, well kept.
Other than a passenger door/ window regulator ( complete kit at O' Reiley's for a mere $71 bucks / 1 hour 10 minutes to replace...... Everything seems absolutely WONDERFUL !!!
06 Yukon XL
My former 06 Yukon XL I bought with 70,000km in May 2008. Had it until January 2017 when it was stolen, It had about 280,000km at that point. Major repairs over that time were both front wheel hubs, rear gears and fuel pump. Not bad for almost 10 years of ownership. Engine and transmission were still strong.
SnowDrifter
Sasquatch Country
My BMW's MANUFACTURER REQUIRED maintenance schedule is to replace the entire cooling system (radiator, waterpump, hoses, sensors, and "must only use" $30 a gallon "BMW" coolant), EVERY TWO YEARS.... \
Year/model? I'm questioning if you were fed a fat crock of shit lol
As far as maintenance on my truck goes... I'm in the 500 to 750 a year bracket for maintenance. Put 12-15k on it annually. It's probably overkill but I need my equipment to perform with flawless reliability. I do a lot of driving in the middle of 'nowhere.' If I incur a breakdown, the privilege of getting to a shop will cost me something around $350, plus cost of repairs, plus the time associated with it, plus (likely) hotel costs and transport to/from the shop. It's worth my time to stay on top of this stuff, even if it borders the side of hypochondriacal maintenance
My maintenance schedule is roughly something like:
Oil every 3-4k. Full synthetic. M1 0w30 or castrol synthetic 5w30. Depends on time of year and what's on sale at the time. Oil filter is either amsoil or fram ultra filter. I drain/fill the oil in the trans pan every other oil change. Front diff gets done yearly with 75w140. Not ideal, but I'm trying to limp it for now. It's boinked. All steering components see a dosing of a synthetic chassis grease.
I'll also take this time to go over belts, inspect hoses, a/c lines, various fittings, brakes, bushings, etc etc, Basically any and all soft parts. And give it a good interior wipedown :p
Annually: Change engine, cabin filter, p/s fluid, sand/touch up any compromised rust areas, rotate tires, check torque on front axle nuts, give the whole vehicle a shakedown. Make sure everything tight is tight, everything that moves, moves. As a final bit, I check t-stat open temp with either my scan tool or a temp gun. Whatever's handy at the time and verify my a/c pressures are in spec
Every 2 years: brake fluid, coolant, trans filter, rear diff fluid, tcase fluid
Almost 14 year old vehicle with 140k on it and there's not a single pop, clunk, squeak, whine, drip, funny smell, or the need to add oil over the course of an OCI.
mattt
I bought my 04 Tahoe Z71 with 140k and it's rolling 280k this month, a little over 4 years later. This generation is reliable, but not bullet proof. There is the Castech head issue and common oil leaks from the 5.3. I'm on the original engine and trans, but both are showing their age. The engine leaks oil, and the trans does slip a very minor amount if you're on the gas, off the gas, and then back on the gas. I've been happy so far, but it is time to either sell it, or dump some money into fixing the engine issues(oil leaks, possible head gaskets or Castech heads, leaking intake gaskets, & a loose front suspension and steering). I did the water pump earlier this year which was a leaker. Trans I will have to have rebuilt when it goes or earlier. I'd be interested to hear what issues others had at the high 200k mark and what they did to fix it.
Good luck with your purchase.
adriver
My last two were a 2001 325/e46 and a 1991 M5/e34. The majority of that is labor at $100-$130 an hour. Feel free to read it right out of the owners manual. There are a lot of specialty tools required, and is as if maintenance was an afterthought. I want to say a head gasket was a 20hr job. Suspension is the same thing, but you don't replace just the bushings, you replace the aluminum control arms, and such. The idea is to replace everything once you think it might start to be questionable. They were fun to drive, but if you're going to bat an eye at spending $5k unexpectedly on a service, than you need to be able to do all your own work.
drakon543
drakon543
well by the general consensus doing a proper test drive and thorough check of the vehicle if everything seems good ill be happy with 150k-180k. if its in super nice shape which so far ive actually found quite a few that appear like they spent thier entire 200k in a sealed garage i could even be temped on a 200k one. my wife does most of the driving with the suv since her work is right in town it doesn't really get alot of mileage.
ShaginWagon
Friendswood, TX
Bought my 03 at 128k. No maintenance records and ran amazing. Trans went out at like 132k. Had a rebuilt slapped in and has been my baby ever since. I’ve already put more money in it than I would have liked, ac compressor clutch went out, air intake gasket, fuel pump. Many other things as well but those boil down to basic maintenance that seemed ignored until I had it.
SnowDrifter
Sasquatch Country
How strange. I looked through the owners manuals I could find, as well as maintenance plans listed on identifix and couldn't find any mention of this.
adriver
Wow, you seem to have a ******* for my posts. Its been close to 10 years since I've owned one. If you want to try to disprove me that bad, go search the forums.
But if were going to play this stupid game... Where exactly DID you look for maintenance, parts and labor cost?
PNWMuseumman
Bow Ties Are Cool
PNW
I have an 02 Z71 with 278k on it, but it has been in my family since new, so it's a cherry picked case given how meticulous my dad is with his cars. These really will run forever and ever. One of the big questions for me when I bought my wife's denali was to find out from the previous owner how much they towed. My tahoe trans has been bullet proof the whole way, but then again it has towed almost nothing.
I try to phrase the question in a way that sounds like i'm doubting it will tow what I want it to, this usually gets people to brag about all of the heavey sh*t they've towed with it.
For me the number I try to stay under when buying is 120k, but my wife's denali was the outlier with 140k but it was in excellent shape.
**One thing to keep in mind on the Denali's / Yukon's, Autoride (if you plan to keep it) is ungodly expensive when you need shocks.
This was the only surprise I had with the denali, but if you're ok doing the delete, then the denali is FREAKING AWESOME!
inmypassatlife
I have been looking at 07+ NNBS Ukon XL and Suburbans, but the AFM shit scares me and I don't feel like spending the coin if it goes out even 2+ years after purchase. That's a lot of upgrades I would rather spend elsewhere than "bulletproofing" due to a manufacturer defect.
I have been looking at NBS Yukons and even Escalades as I can find those in decent condition in the 150-180k range with clean titles and decent carfax/autocheck history for $3-6k.
If you need any discounts on Carfax/Autocheck let me know. I got a hookup
Towmaster
