125k miles. I'm mechanically inclined. But not enough, nor do i have the tools to do a job like that.Mileage drop could be just how the truck calculates MPG.
If you have been driving mostly on the highway and the computer is calculating mileage based on continued running at a given speed and then you speed up your mileage will drop or if you get off the interstate and start driving in stop and go traffic the MPG will go down. The DIC is only "so" accurate.
Smoke on start up could definitely be from all the oil in the intake as I described.
Worried about lifters failing... I'm not sure how many miles are on your truck but it could happen with any of these trucks... obviously higher mileage would be more prone to it but some guys have had trouble with less than 100k miles.. changing it for a different year really isn't going to change that.
Do you have any lifter tick???
If you are mechanically inclined swapping out the cam and lifters should only cost about $1500 for a decent upgraded cam and non-AFM lifters and all associated gaskets and parts and such.
I thought everything I'd read was after 09 they fixed the issue. Other bonus would be six speed. Literally settled for this truck because of price and how clean interior and maintenance records were. I find it hard to believe the issues just started. But theres nothing in all the dealer records about even checking for oil consumption. And it had every single oil change done since it was new at a dealer.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Even if it is lifter that's not a huge deal. Just replace them, tune out the AFM and move on. You'll be good to go for a long time after that.
