D-Pillar speaker revisit - purpose and connections
Meccanoble
Georgia
The speakers in the far back of the truck are the ones I'm referring to. Their position seems to be more of a "filler" position rather than a dedicated high or low like a tweeter or subwoofer. My audio expert friend confirmed they were a filler and not associated or connected with the rear door speakers, well maybe for power/signal but not a partnership like your standard components. Trying to replace speakers on stock amp in a way as if they were components would supposedly create sound problems. Not to say this feedback is true but it makes sense. The size of the speaker (3.5") gives it the ability to handle a wider spectrum of frequencies than just a tweeter or just a mid driver and its positioning, confirms it further, being in the far rear. Its almost like a center speaker. There is no dedication to highs or lows, just kind of fills the void.
It basically seemed worthless to upgrade this speaker under the stock amp setup unless you were going to change the amp it connects to which should then change its role or frequency range.
Anyone that swapped this speaker out on a stock setup hear this feedback? I assume if you tried to swap it out with a componenent set without using a crossover, its ability to play sounds as compared to tweeters elsewhere in the car would sound limited.
Instead, the rear door has a component set coming from just the rear door wiring alone. A crossover was added to the wiring to control frequencies that go to tweeter. Since speakers are now sharing the same power that came from amp, the combination wont get that loud but its just rear fill and plan to add amp later to pump up the power a little. But based off feedback I received, unless going aftermarket with amp, it doesnt seem to be ideal to consider that d-pillar speaker a matched componenet set with the rear door, which is what I was hoping it would be atleast (assuming people here already knew this).
kbuskill
NE. FL.
Just out of curiosity.... what Ohm speakers did you replace your rear door speakers with???
The factory rear door speakers on the Bose system are 3.6 Ohm. I replaced mine with 3 Ohm Infinitys.
M
Meccanoble
Georgia
I had some 4 ohm Helix Components I took out of a previous car. Honestly, they sound dissappointing because not only are they a higher ohm than the originals, but 4 speakers are getting power from wires that were powering 2. Its good enough for rear fill but I'm a cranker. Plus, my expectations were high, forgetting the amount of power they will have to share. Plus they are rated to take 70-125 watts and probably getting 20 rms max from HU. Thats like 10 to each speaker? Aftermarket radios only push low 20's at best. I had a busted yet working bose speaker on one side so it still sounds better than before but after hearing what my front end is doing with an aftermarket amp, its disappointing but understandable what the rear is doing.
Anyone that feels rear fill is not necessary or truly believes in what rear fill is 'supposed to be' will be content as it definitely serves its purpose but I'm a cranker. I definitely would waste money on components in the rear unless I was planning to get amp for them. Coaxials would definitely be enough.
kbuskill
NE. FL.
The 4 ohm speakers are causing you to loose some volume.
Your setup with 4 ohm doors and stock 12.5 Ohm D-pillars = 3.03 ohms
Factory door speakers and D-pillars = 2.79 ohms
My 3 ohm doors with stock D-pillars = 2.41 ohms
So mine are slightly louder than stock.
I think your biggest problem is probably the wattage rating and possibly the sensitivity.
My Infinity PR6500CS 's are 5-80W RMS and sensitivity 93db.
M
Meccanoble
Georgia
Agreed. Whether its a coaxial set or component set, the ohms & sensitivity will play the biggest role with how loud it gets.
Regarding the D pillars, anyone replace stock speakers in D Pillar and notice its not playing right? I wouldnt mind throwing better tweets in there if I knew it would play the frequency range I wanted
M
Meccanoble
Georgia
Question, if the D-Pillar speakers were disconnected, that would put more power to the rear doors right? I believe they are somehow connected together (rear doors and the d-pillar) so maybe cutting certain wires on amp will stop them from working and put more power to rear doors? Or would I have to disconnect from the speaker side since they run as 1 unit into the amp?
Just looking for cheap ways to improve sound :)
kbuskill
NE. FL.
Kinda sorta maybe not really.... lol
I don't remember what speakers you are running so I will just use the factory specs as an example.
Factory rear door speaker = 3.6 ohms
Factory D-pillar speaker = 12.5 ohms
For a total load seen by the Amplifier of about 2.8 ohms
If the speakers are wired in parallel, which they are, then the lower impedance speakers will draw more power than the higher impedance speakers.
So your door speaker is already getting more power than the D-pillar... it's not like a 50-50 split.
So by disconnecting the D-pillar speaker you will send all 100% of the power to the door speaker BUT you would also increase the ohms seen by the amp from 2.8 ohms to 3.6 ohms which will mean less power from the amp.
What I'm saying is it MAY be a wash.
The easiest thing to do is unplug the D-pillar speakers while playing a song and see if it makes any noticeable difference.
M
Meccanoble
Georgia
Speakers in rear door are 4 ohms. From your feedback, there wont be a big improvement and I never opened up those D-Pillars so I'll wait until I'm ready to change an amp or something before I open anything up. Thanks for the feedback. I always thought it was a 50/50 split....
when I had my nbs I changed the rear pillar speakers to 3" I don't recall the brand name, they where European and had big magnets I had to cut away some of the back of the pillar cover plastic with a razor knife to make it work but when the covers were put back on you couldn't see the difference. I then ran the pillar speakers on the amp from the head unit (pioneer) and the door speakers were on a amp I put under the seat and the subwoofer had it's own amp. overall all it just added more sound if you were in the back seat you could hear them rather than the door speakers. I had also added the bose front pillar tweeters in addition to the front door tweeters.
kbuskill
NE. FL.
If they were both the same ohms then it would be a 50/50 split. If you changed your door speakers from those 4 ohm to 3 ohm you would get a "little" more power to them and therefore a "little" more sound.
Right now you are running approximately 75% of the power to the 4 ohm door speaker and 25% of the power to the 12.5 ohm D-pillar speaker.
Swapping to a 3 ohm door speaker would only result in an 80/20 split, so not a drastic difference.
Unplugging the D-pillar speaker would result in 100% power to the door speaker BUT it would be at 4 ohms instead of the 3 ohms your currently running.
From the results above when changing from the 4 ohm to the 3 ohm we see that it is only a 5% difference in power so in theory you would still net about a 20% increase in power so it might be worth it.
Pulling the D-pillars to unplug the speakers wouldn't take very long and I would be truly interested in the results.
If you don't do it then I may be forced to... lol
Interesting read. I thought it was a tweeter back there so I was planning on installing a component set with the main speaker in the door and it's accompanying tweeter in the D-pillar. I thought it was a calculated design for those sitting in the second row to have highs but not blaring in their ears.
M
Meccanoble
Georgia
This would be a cheap (free) upgrade. I'm definitely doing it. Was trying to find feedback on how to take those panels off and ran into these details. Someone put a 4" back there successfully with some trimming. They also seem to speak positively with just replacing that speaker. Being that its a 12 ohm, if it was replaced with a 4 ohm, that would greatly increase the power right?
Since the front 2 channels of my bose amp are not being used, is there a way to focus all the bose power into the rear doors/d-pillar? I'm still lost on how this "parallel" runs. Somehow the rear doors and dpillars connect into 1 which goes into amp? If they go into amp seperately but share a channel, maybe we can cut the connection of rear door speakers to amp and redirect to where the front speakers connect. Do the same for the d-pillar speaker connections to amp and redirect to the rear door speakers. Seems like a little work but free additional power. Upgrade the d-pillar speaker and now system would really shine?
Notes on how to remove D-pillar panel:
"No special tools required.
Pry off the oval shaped screw covers on the pillar panel (they face each other in the hatch opening). Remove the screw under the cover.
Reach your fingers between the side glass and trim panel and pull the panel toward the front of the car. This will unseat the plastic "push in fasteners". Then un-clip the panel from the headliner trim."
https://chevroletforum.com/forum/tahoe-suburban-25/2011-suburban-d-pillar-speakers-42372/page3/
M
Meccanoble
Georgia
THIS IS WHAT I THOUGHT AS WELL!!!! I had an extra component set and was going to do this but my install guy told me the speaker(s) would sound terrible in d-pillar because that channel not setup for full sound, just fill. If we were using our own amp or maybe tricking the bose amp into thinking that d-pillar wiring was really rear or front door wiring, maybe we can work some free magic....
M
Meccanoble
Georgia
Actually, since I have aftermarket HU, I can connect the rear door speakers to HU seperately and leave d-pillar speakers on bose amp right? I just need confirmation that the d-pillar speakers and rear door speakers connect to bose amp seperately. Even if they share, just means I wont have to run wiring, just tap into where they connect to amp.
M
Meccanoble
Georgia
I disconnected d pillar speakers. Not sure if it made a difference. The rear are loud enough but 20% improvement on nothing much is still nothing much. I hear you have to double power to hear a difference? I don't have good enough ears to properly test but the prices of unplugging is real easy, a little tricky on driver side.
kbuskill
NE. FL.
Did you have something playing while you disconnected them or just do a before and after comparison?
M
Meccanoble
Georgia
I didnt. My neighborhood is super quiet and couldnt test the way I really want to. I'll try a walmart or something to test out.
I dont think anyone has confirmed this but are there just 2 wires goign to amp for the rear door and dpillar speakers? If so, an upgrade with amp and keeping wiring will power all the speakers (unless dpillars are disconnected). In the future, would love to throw some 3-4" drivers back there and power rear doors and d-pillar from same amp/channel.
kbuskill
NE. FL.
Not sure on how many wires are connected at the amp... wiring diagram might tell you... @swathdiver
veteran111
