Z55 Air shock replacement
Trailblazzin
Lancaster PA
I ordered a set of replacement shocks for my 07 LTZ. Went with ACDelco's. I noticed both bladders on the outside of the shocks were frayed and appears to have holes in them. My compressor would always kick on after the ignition was turned on. The pump would run for a few seconds and shut off. Also, while trailering with a couple hundred pounds of tongue weight the pump would pump for 45-60 seconds and appeared to raising the squatted rear end.
I have removed the fuse to prevent the pump from running and burning up.
Never had a code or service suspension light on the dash either.
Is the outer bag on the shock I see the actual "air bladder" or is there something else inside of that "cover". I don't understand if they air leaking why the pump wouldn't run longer.
I'm leaving for an 8 hour drive trip and will be loaded. The replacement won't be here in time, and I wanted an opinion on putting the fuse back in.
kbuskill
NE. FL.
The frayed bladder you see is the actual air bag bladder. Leave the fuse out until you get your new shocks installed unless you want to have a new pump to go with your new shocks.
The ESCM will turn the pump off after 255 secs to keep from burning it up. Depending on how big the holes in the bladders are it may be a slow leak.
Trailblazzin
Trailblazzin
Lancaster PA
Thanks, I’ll leave it out until i get the new shocks in. Does it sound like my pump is shot too? Do they still sound like they are pumping when they burn up?
kbuskill
NE. FL.
If you still hear it running then it is likely not burnt up BUT the longer you allow it to run with bad shocks the more moisture it will collect in the air dryer which will reduce its life expectancy.
They usually get really noisy before they crap out in my experience.
I replaced mine with the Dorman replacement compressor.
Trailblazzin
Trailblazzin
Lancaster PA
New shocks installed. They are slightly different from original in that the body seems shorter, but are the same overall length.
Trailblazzin
Trailblazzin
Lancaster PA
I feel like my suspension is harsher, not as smooth as when I first got my Tahoe.
Is it possible that the electronic shocks/struts are stuck in that setting? Anyway for me to tell?
Both rears replaced recently and last year I replaced the drivers side strut, haven’t gotten around to the passenger side yet.
kbuskill
NE. FL.
You can unplug them and see if you notice a difference in the ride. You will definitely get a light on the dash but you should notice a softer ride.
Trailblazzin
Trailblazzin
Lancaster PA
Good idea, so when they are disconnected, the revert to the softest ride?
There isn’t a calibration that needs completed after replacement though, correct?
there is a calibration that can be ran with the tech2 I did it on mine but it made no noticeable difference, also your pump is supposed to run each time you turn the key on, it is a self check and runs each time for approx. 4 seconds, also the pump will come on and inflate the shock if weight is added that's the whole purpose of the system.
kbuskill
NE. FL.
Just to clarify... when I said unplug them, I was referring to the electrical connectors on the front and rear shocks NOT the air lines on the rear shocks.
As @Doubeleive mentioned... the air compressor should start and run for a few seconds after start up, as a self check, and anytime enough weight is added to the rear.
If it isn't running as described then the dump valve could be bad, which should set a light on the dash.
If you loaded the rear heavy and the compressor aired up to compensate for it but couldn't release that air when unloaded then it would cause the ride to be stiff/harsh in the rear.
If you don't hear the pump running or dumping when you turn off the truck then this could be the issue.
If this is the case you can disconnect one of the air lines at the shock to evacuate the air and then reinstall the line and see if it airs back up when you start the truck and then test drive it.
I can hear mine dumping air right before it kicks on when I turn the key on
kbuskill
NE. FL.
That is correct. It opens the dump valve to release any compression built up in the pump to make it easier for the compressor to start up and reduce the initial amperage draw of the compressor motor.
I also can sometimes hear mine dump after turning the truck off when I get out.
TejasPitt
