TARDIS
Jersey Shore
Completely New A/C System for my 96 Yukon.
6BFA4709-BDDA-45E1-84D0-031D6F8817FB.jpeg 96CC4B9E-1D50-4600-BDB3-7E56911A6DB0.jpeg
fastpat
Upcountry South Carolina
@SunlitComet - I just purchased the Flex A Lite 280 dual electric fan bolt on kit for my 99 Hoe with the 5.7L V8. I know the manufacturer writes the unit draws up to 28 amps. I was thinking this might also be a good time to upgrade my alternator from the stock 105 amp to at least a 140 amp unit. Yes? No? Any suggestions on a make/model I should go with?
I also would like to know if you think I should upgrade the battery cables and the power cable from the battery to the alternator with thicker gauge cables - a 2 gauge? 4 gauge? I just want to make sure I don't burn up my electrical system by adding this dual electric fan set-up and I'm supplying the power the system needs, especially when the vehicle is running at idle with the AC on max and maxed out fan speed in the summer heat in Phoenix!
Thanks!
What is your voltage reading now? After the battery is recharged from the draw down of starting the truck, it should settle on 13.8 volts plus or minus a few tenths. I'm installing a fresh battery today and have a 200 amp alternator on order. I don't need 200 amps, but wanted the 100 amps available at idle.
It was 95º here yesterday afternoon and the A/C ran out of cold while idling, indicating I may need a set of aux fans, too. We'll see.
'99_Tahoe LS 4WD - AZ
Phoenix, AZ
Hello @fastpat .. yes, I sit at right about 13.8 amps on the gauge upon start-up and idle and it drops down to about 12.5 to 13 when I turn on my car stereo (stock), LED headlights and AC on max speed recirc all at once. That's really the only major combo power draw I currently have. I figure the FLA 280 will drop it down to around maybe 10 or 11 so I want to be prepared with a higher output alternator. I did upgrade my battery recently to the mega deluxe model at Auto Zone (that sucker was about 200 bucks!).
DallasTahoe
I’ve got a 140 amp alt and I upgraded my wiring to 0 gauge grounds, and power cables. With everything on including 3 pairs of auxiliary lights and efans and and 4hi mod at idle I’m at about 13.7-13.9. Of course I do have a second battery as well
fastpat
If your wiring, battery, and alternator are all in good condition or better; you shouldn't have that kind of voltage drop. For your issue I'd recommend you upgrade your alternator to battery cable, either to 2 gauge or 0 gauge. I'd also recommend you remove and replace your under hood ground straps, cleaning off the ground attachment points on both ends.
Looking fresh, the white tripped me out as well, good to know that’s how some are coming now-a-days. And gotta ask what is all this stuff in the red circle?
Yep, just garbage from the previous owners. Like @Galante said, caked up grease (grease zirk is under there somewhere), road grime and debris....I had to knock a bunch of that crap off while i was in there. I never did get it perfect because I'll be doing ball joints here really soon anyway and it'll take care of itself then. The previous owners of this thing must have lived on a dirt road and never cleaned a thing. There's crap like that every where underneath this thing. I'm gradually getting it all cleaned up but it would take me a solid week to truly get it all clean if I didn't have a job I had to come to every day LOL
Shadowz Edge
Well it was to try and buy some LED bulbs to upgrade the lighting (only 2 lights work in the entire interior) but they were sold out.
00'BlueSteel
Carolina
Ah, I was thinking that’s what it was but wondering if maybe it was someones lost pet or some other road gold lol. And I hear ya on all that, work, not enough time, and previous owners, the car guy 3 worst enemies.
Phoenix, AZ
Great ideas and suggestions, @DallasTahoe I'll do that! I only have one battery, though, as I have that damn California emissions equipment on the driver's front corner under the hood where the second battery would have gone.
TARDIS
Jersey Shore
0BFCC5B3-4973-4DDE-A27F-CB66499BCE41.jpeg CARPET CLEANING
22 years with the original owner, I inherited a lot of coffee and miscellaneous dark stains in my light grey carpet.
I was shocked how 409 Carpet Cleaner took so much of the stain out with just a little effort.
...and it smells good too
11FBA756-4BB5-4552-AA66-C10A70F30355.jpeg 37BEB754-FEB1-499E-BE7C-E280D08D6C21.jpeg D7E5FD6B-EAB9-430D-86D6-F7BAD574FC1B.jpeg 2B180E85-290F-4C93-8B3B-E2FCD6ABA699.jpeg
The last picture is the BEFORE, the second last is the AFTER (after 3 minutes of soaking and a minute of scrubbing)
DallasTahoe
Well since it’s been super hot here in Dallas, (it was officially 108 today) and I haven’t been able to run the ac unless I’m flying down the freeway (which sucks). I’ve been doing some changes, first off changed the coolant, then today pulled out my efan setup, got rid of the sheet metal mounting panel and reinstalled them directly to the radiator, then reinstalled the original 11 blade fan and shroud, we’ll see how well it does tomorrow
Elite
I've had my '12 for a week, last night my wife pulled up at a middle school, walked 100 yards away, picked up my son from football practice, walked back, and we were 1 of 3 cars with smashed windows. New purse...gone. Tint is super dark so had to have watched her get out. Getting it replaced today, then have to find a shop to match the aftermarket tint.
fastpat
Your 2012 belongs in another forum, this one is for 1991-1999 trucks. While we welcome to the Tahoe/Yukon forum, we think you'd have a better response in the forum for your year of production.
HiHoeSilver
Away!
Chicago
This sucks! Every time I hear a story like this it reminds me of my uncle. He had a mailbox that was getting smashed, replaced, smashed, replaced. He noticed the pattern and waited hiding one night. Put a sledge hammer into the hood of the kids car, said "explain that to your dad." and walked back inside. Lol. Gotta love the vigilante at work!
fastpat
Same had happed here, to the previous owners. I put up a Veeders make box. No further problems.
http://veedersmailbox.com
Korbin_A
