Lowering with DJM
Num12005
So,last year I ordered and installed a 3-4 drop from Tony.The front I djm 3"lowers,after the install an alignment,the truck wanders,road walks and horrible bump steer.It didn't do it before.So,what is everyone's opinion on the djm uppers??Think it would help my issue?I know their are alot of factors to the wandering..Just curious on the djm uppers,thy worth it??tia
I've heard others with problems with the DJM lowers and how they're designed. You're not the first to experience wandering. Have you contacted Tony?
Num12005
Num12005
Yes and he didn't have any response.So pretty much stuck with them.Im about to double down and order the uppers,lol.Im hoping they'll help??
I'm just curious: do your jounce stops make contact with the DJM LCA's?
Num12005
Num12005
Nope,i went through all that when I installed them and came to the result ,don't run jounce stops.Tonylso told me to not run them..
That's what I don't understand with the DJM's, since from all that I understand about the torsion bar suspension they're an important part of the design. Tony nor nobody else has explained why they aren't needed when you use the DJM's.
Num12005
Num12005
I agree man,i even called djm and the guy was a total douche.He couldn't tell me at all.I wish my problem had a easy fix like a jounce cause let me tell ya,ive been disappointed with the control arms from the minute I drove it the first time.Its a handfull to keep between the lines.Gonna try some tie rods first(even though they don't have any play)..After that I guess I'm gonna get the upper DJM's ,sure is hard to spend another 275 on a product I've hated so far!
Shortstock
Life is good today!
Prairieville Louisiana
Screw that just get belltech drop spindles and tweak your stock torsion bars and you will be happier.
NORCAL SS
SUV SUSPENSION GURU
Do you have the alignment sheet shoot it to me
briannorris
