Bose speakers ???
kbuskill
kbuskill
NE. FL.
Ok.... who wants to pull the A-pillar tweeters to see if they have the ohms marked on them???
Anyone..... anyone at all?
kbuskill
kbuskill
NE. FL.
I have been looking at replacement speakers and so far I am leaning towards these...
Use these 2 ohm speakers in the front doors to replace the 1.9 ohm Bose.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/281455130524
Use these 3 ohm speakers in the rear doors to replace the 3.6 ohm Bose. And install the tweeters in the A-pillars.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/281418708964
The only thing I am not certain about is the ohm rating of the Bose tweeters and how they are wired. I would think they are parallel with the front door speakers which would also effect the ohms the amp sees.
I also considered leaving the factory tweeter and running these in the rear doors instead.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/302596977226
Any and all opinions welcome.
Any of those numbers make sense, other than the part number?
Shaw520
Those are all good choices,. I like Infinity speakers
kbuskill
kbuskill
NE. FL.
No Sir.... that is all I could find in pics online as well.... I guess they are probably not marked.
May have to pull one and check it with a ohm meter..... yes I know it won't be accurate but it is better than nothing.
No worries... I am installing the "dynamat" on the rear doors today so I pulled the rear speakers.
2008 Suburban LTZ non-LUX Bose system...
1.9 ohm front door speakers
3.6 ohm rear door speakers
So looks like 2 ohm front and 4 ohm rear replacements would be in order.
Not sure how 2 ohm speakers in rear would affect the amp or the sound... I would assume the rear speakers would be louder but it may cause the amp to run hotter.
I am going to wait a while and see how sealing/sound deadening the doors is going to improve output... who knows, I may not need to upgrade.
Before...
After...
If you have speakers in the very back like the NBS they may be wired in parallel with the rear door speakers. I'm not sure if the NNBS have the C pillar speakers or whatever they're called. Mine are a weird size, I don't remember the specifics.
GranPrix
Before...
After...
How's the "dynamat" on the door with road noise?
I came across a post from some forum last night that said the front door and this tweeter were wired together so my understanding is that the tweeter is also about 1.6 ohms so that it and door do not exceed the rear door ohms. Does that make sense? Let me see if I can find it...
Here, 6th post down:
http://www.silveradosierra.com/mobile-electronics/new-speakers-with-bose-amp-t114313.html
Did you check for rear speakers by the hatch? Some people don't even notice they're there.
kbuskill
kbuskill
NE. FL.
Yeah it has them in the D-pillar but I am not worried about changing those out.... that's like a hundred miles away from where I sit.... lol
kbuskill
kbuskill
NE. FL.
Yeah, I saw that as well... the only thing that doesn't jive for me is he said the rear speakers are 4.8 ohm.... which doesn't match my 3.6 ohm speakers in the rear doors.... and I don't think he would be referring to door + D-pillar speakers because he had a pickup.
But what you said would make logical sense to me... making the front and rear impedance match. I'm just not 100% sure how many channels the Bose amp is.
I was just mentioning those because they're on the same channel as the rear door speakers I believe so the actual resistance on those channels depends on if they're wired in series or parallel with the doors. Same goes with the tweeters on the a-pillars. I'm pretty sure they're wired in with the front door speakers. The systems on our trucks have so many different combinations, with the non-Bose, standard Bose, and Lux Bose, that it's hard to figure out what's what with the stock speakers and how they're wired. When you're changing out speakers and you look at the rear door speakers and they're 4 ohms you might think the rear channels are 4 ohms as seen by the amp or HU but if you factor in a d-pillar speaker that's wired in parallel or series that figure obviously changes.
kbuskill
kbuskill
NE. FL.
Agreed.... I just figured since the rear doors are 3.6 ohm I could go with either a 3 or 4 ohm speaker and be really close. I just thought I would rather go 3 ohm for a little more power.
What you just stated is why I am debating changing the A-pillar tweeters or not. If I don't change them then a 2 ohm speaker will be just about perfect to replace the 1.9 ohm Bose in the front doors.That is probably the route I will go.
I was only considering swapping tweeters because the one set of speakers I was looking at came with tweets.
kbuskill
kbuskill
NE. FL.
So in the expert opinion of the jury.....
Would you go coaxial for the rear door speakers or should I buy the components and just keep the tweeters and crossovers for a rainy day and install the mid bass drivers in the rear doors???
I cant really hear my rear door speakers. I went with coaxials there.
johnsonwillie199
