Ridechevy09
Nex axle setup for the tahoe
Sent from my SM-G935P using Tapatalk
Is that a 10.5" axle? It looks bigger than the 14bolt 9.5" axle I haveNex axle setup for the tahoe![]()
Thanks but i didnt put up the frame rail pics.....I was messing with the Tech2 in a parking lot and came across an entry labled "Valet Switch". Anyone know what that's about? Not mentioned in my owner's manual or a cursory search in the main shop manual.
Underneath looks good for being in Yankee territory!
What kind is this?Nex axle setup for the tahoe![]()
So....... what’s with the valet switch?I was messing with the Tech2 in a parking lot and came across an entry labled "Valet Switch". Anyone know what that's about? Not mentioned in my owner's manual or a cursory search in the main shop manual.
did the swap to the dual 700w cooling system 7/9 blade, it's pretty apparent that it is heavier duty than the stock dual 5 blade, fans and motors are bigger and have more weight to them. installed brand new motors in the housing so I should be golden for a good while.
View attachment 193462 View attachment 193463
Look in herehttp://www.tahoeyukonforum.com/threads/electric-fan-mods.100757/You have info on where you got all your parts? I may be interested in this. Seems like a nice mod especially for those in hot places who do a lot of towing.
Hey your tire fell off!!! Don't drive it until you tighten those lug nuts!Thanks but i didnt put up the frame rail pics.....View attachment 193458View attachment 193459View attachment 193460
I purchased a used assembly from a hummer, it had 200k on the clock so just to be safe I purchased new motors from rock autoYou have info on where you got all your parts? I may be interested in this. Seems like a nice mod especially for those in hot places who do a lot of towing.
Mine's a might worse than that. It's from West Virginia. I was thinking of getting under there one day with a brush and baking soda and then coat everything in tallow or oil afterwards. One of my Montana's is from Wisconsin and it had rust/rot on ancillary parts but not the body or suspension. Been two years and hasn't gotten any worse. I'll be under the truck next week doing the cats and will think about it more then.
Did your wife see you lean that tire up against that other car???
Thats the commuter accord with 325k.... talk about rust... iv garaged it since new 10yrs ago and last month i found this....![]()
Valet setting:
On newer trucks there's a setting in the radio/nav unit for a rev limiter or something i was reading last night. Dont know about nnbs’s tho
I lost themHey your tire fell off!!! Don't drive it until you tighten those lug nuts!
At 110 mph it began to levitate and at 120 would fly out of the footwell and fly around the interior!
