87 octane vs 91 octane
Dave, that knocking and pinging is why your #4 piston fell apart. It costs more money, not less, to run the lower octane fuels. Run three tanks of each and note the difference in fuel economy.
adventurenali92
Big Bear Lake, ca
  • High desert. We have two locations and both qualify as high desert, I believe. As others have said, you've got a high priced vehicle. Not wise to go cheap on its fuel. I not only run 91, but only Top Tier. Not hard to find, just look for it.
I hope you don't plan on scrimping on oil, too! :badidea:
High desert as in apple valley?! Victorville?! Didn’t know there were any other members so close haha
Lalo
Chicago
I tried running regular in my 2015 Denali you definitely feel the difference only put in premium because of the higher octane , when you use the loweroctane fuel your knock sensors will tell the ECM to retart the timing also your car is also drive by wire so it will protect itself from detention but you won't have the full power of the 6.2 ...which was a selling point for me , I would stick to the premium on the 6.2 ....
Ruby Roo
Ruby Roo
High Desert
Thanks Lalo.
The 6.2 was a big selling point for me also. I love the looks I get from people on the freeway when you accelerate past them.
Scottydoggs
NJ
if you just bought a newer truck that cost as much as a damn house in some places, you can afford the higher octane. whats anther 8 to 10 bucks a fill up when you likely carry a 1200 a month or more payment already.
if you cant afford this extra 10 bucks a fill up you bought out of your pay scale.
gonatee
What does California not sell
93 octane? Why tf do I still live here lol!
Scottydoggs
NJ
well CA has to many issues to even get started on that.....lol
but states in higher elevations dont need 93 they say, less air density, so they get 91 and no higher.
Vector
South Florida
you're only saving about $4 every full up and that's if u fill from empty. even if u fill up every week that's probably less than $20 a month in difference which I hope since you have a basically brand new truck isn't a big deal
I've seen a few of these posts, and I guess depending on where your live, the cost can be that small. However in some cities like the one I live in, if your price difference is roughly $0.70 more for premium and your tank holds 30 gallons, you are talking about a $21 price difference per tank.
Consider it this way JC:
87 octane is $2.39 a gallon and let's say 26 gallons to fill up. That's $62.14 and 87 in our mythical truck returns 14 mpg for a range of 364 miles. That's $.17 cents a mile.
93 octane is $3.09 a gallon and let's say 26 gallons to fill up. That's $80.34 and 93 in our mythical truck returns 16 mpg for a range of 416 miles. That's $.193 cents a mile.
Not much difference in price when looked at this way, big difference in performance and in the care and feeding of the motor.
It costs me (with a bad cat) about $.24 cents a mile to run 93 and $.19 cents a mile to run E85 on average for both as fuel prices are ever changing.
CMil527
Old Bridge, NJ
If the gas your using is not correct, your engine will let you know by spark knock or poor performance. If you notice on the pump, their method of determining OCTANE rating is of + or - 2 which is to be considered. Sometimes I wonder just exactly what your paying for, it is what it is. My 5.7 runs fine with the 87 octane with no lag in performance or spark knock. JMHO.
David g............:)
agreed 110% I've never had any issue running 87 in my 5.7 Hemi's!
Vector
South Florida
I am not saying you are wrong, far from it. However not everyone gets a tangible increase in fuel efficiency when going with higher octane. If people are not experiencing detonation or other maladies from lower octane, your aforementioned example is not necessarily accurate.
For high performance engines I do only run 93 or even 94 if I can find it. Heck on occasion, I'd have jet fuel grade gas regardless of cost if performance was demanded, fuel efficiency be damned.
Still, with regular demands on typical driving scenarios, I am not sure any of out 6.2's really benefit that much between low and medium grade fuel.
Lastly, where I live in S FL, price differences can be greater than $0.70 per gallon. Heck there was a $1.02 difference between regular 87 in one part of the county vs. another for 87 grade.
I am not even sure what the difference was for premium, as I was in shock at the difference for the same grade.
HACK BLOCK
NYC
different prices for the same grade
should be expected in different areas
HACK BLOCK
NYC
either way u should run 93. if I was buying a used 6.2 truck and knew the previous owner put 87 all the time I'd probably pass
PG01
Up here to the right
@BlackBearPerf @JennaBear @Justin
You guys care to clear this up....lol
PG01
Here’s some nice pics....
Vector
South Florida
It is almost laughable that someone owning a truck that expensive would put rat piss gas in it! In short, you could easily grenade your high performance, high COMPRESSION engine with the wrong octane gas!
http://www.hotrod.com/articles/eliminating-detonation-pre-ignition/
I get your point, but not everyone that buys an Escalade (especially used) is a "baller". Furthermore, many a report has come out over the years to show very few cars (typically high performance) that suggest or call for premium, actually need it.
Now in my ZR-1, it gets premium no questions asked. Still places like Consumer Reports claim in most cases it is just throwing money away based on marketing.
JC, I've been proving this point for thirty years from Toyota Corollas to my new to me Yukon. I'm just north of you and the spread between high test and low is shrinking again, it used to be just .10 cents per grade difference not so long ago. Today, at a top tier Mobil station nearby in Jensen Beach, the spread is $.60 cents, $3.15 for 93. Last month it was $2.87 for a week or so. Even E85 went up from last week, about twenty cents a gallon.
As I've said before, y'all have to work out which Top Tier fuel works best in your auto and where to buy it at the best price. I've seen several mpg differences between Top Tier 93 among stations, my Montanas run awful on Shell's 93 compared with Sunoco and run even better on Mobil and Chevron. My truck is bearing that out too.
And, last time I checked the lower octane fuels do not have the additives that contribute to keeping the fuel system clean, that alone is worth the cost to me. A great many of the driveability problem posts are because of folks running that cheap gas. One gets what they pay for, seemingly anyway, it costs more to run cheap gas than good gas.
adventurenali92
Big Bear Lake, ca
Ironically here in California, shell has excellent gas. Which is what I buy here in big bear, but unfortunately 91 octane which I run my 6.0 on, is 3.55 a gallon. Ski town jacks up prices. But at Costco down off the mountain, which has good quality gas I’m spending I think right around 3 a gallon. If I have rewards points built up from my groceries, I can go to chevron and pay just under 3 a gallon for 91 octane, that isn’t that often though. It’s true, you get what you pay for, cheap companies cheapo gas and you’ll get ****.... lol
Drewphil
