2015 Yukon XL Denali 6.2L Starter part #?
PitBullFan01
NYC
Anyone know the correct part number for the starter for a 2015 Yukon XL Denali, 6.2L (no Flex, runs on Premium)
I checked Rock Auto and they have one GM Original which is GM GENUINE 12740952. But, when checking the GM parts site, that part says its for for 4.3L engine and the only other one I see on the GM site, GM 12736813 says for 5.3L. So, can I use either one of these or is there one specifically for the 6.2L engine? Thank in advance
Rygrego
Mission Viejo, California
According to your title you've come back in time. The updated current part number is
GM #12740952 which replaces the old 12724245. And your part # 12740952 was replaced by 12724245. So your number should work just fine.​
Fless
Super Moderator
Elev 5,280
The two statements conflict. The second statement likely should read "And your part # 12740952 was replacesd by 12724245.
Or is this all backwards?
PitBullFan01
PitBullFan01
NYC
The 2 statements you wrote conflict. Is the correct part # 12724245?
Fless
Super Moderator
Elev 5,280
From GMPartsDirect.com:
You've been given good advice above. For your future reference, go to GMPartsDirect.com, enter your VIN, and you will find the part numbers that you need. The site also references obsolete part numbers, so you can see the chronological transition of replacement part numbers.
Brs2427
