Let's see Your Before and After pics
00chevyHd
22's in winter, 26's in summer. 2/4 drop with spindles in front and Belltech springs in the back. Thanks for the compliment!
Thats Nice And Does It Rub On Fender Wells when Having more than 3-4 passengers ????
Youre welcome man
02esky0FKSGVN
Let’s see ....
BEFORE
And AFTER
00chevyHd
Leaf Spring right ????
Okay And this Sounds Stupid lol So If I get The. 2" Spindle drop thatd do it right like i dont need torsion key right ???
And For Rear Do i get leaf Spring? Shocks? lowering Blocks? Lowering Coil Springs? Shackles?? Im Just Confused
2" front drop spindles for 2"drop without changing front suspension geometry. Stock keys can be adjusted another inch if you want it lower. More than that and you need drop keys but then you need shorter shocks. The rear has coil springs and you can get 4" lowering springs and then you need shock extenders so your shocks don't bottom out. More than that and you'll probably need to cut the lowering springs. Tony aka @NORCAL SS is a vendor here and can set you up with the best price on a kit. Send him a PM and tell him what you want to do. A 2/4 drop is pretty common and the truck ends up level.
00chevyHd
I Appretiate it man thanks for the info
Big Jim
