Thinking of switching to smaller wheels....
NathanJax
Vacation Nathan
Jax, Fl
Why?
Is it a ride issue? Cause that won't solve it...
Is it a looks issue? Cause those will look worse than your 20's...
Brian1971
I have 20's on my LTZ. Bought a set of used 17 and installed a set of winter snow tires, they ride just as good as the 20's. I was really surprised. I figured it would degrade the handling, no problems and I got better winter traction. Win/Win!
BTW, I swap them out every season.
Trailblazzin
Trailblazzin
Lancaster PA
Why?
Yea kind of a ride issue, doesn’t take the pot holes and overall terrible pa roads to well. It handles like a dream, can corner really well for a vehicle of this size. Cruising on the highway is also good, but lots of harshness I was trying to convince myself that this would solve. I also have brand new struts and shocks, it has the auto ride z55 rpo and replaced with all new oem components.
Trailblazzin
Trailblazzin
Lancaster PA
Does it help with the harshness of bumps? I’ve read up and people say it doesn’t but I find that hard to believe, I had a Trailblazer prior to this and had the stock 16” and also the SS 20” and it was night and day.
cekkk
SoCal
No question, my 22" rims and skinny tires look great. And if I never had to drive it, I'd love them. But I do take them out of the garage on occasion. Special order Michelins, special in that nobody had them in stock, ride very rough. And God forbid I should hit a pothole. About a waste of $3k.
I think you won't regret the trade-off of looks for money saved and better ride. But only you can decide.
Meccanoble
Georgia
I had 17's on Dunlops that I just removed for 20's on stock good years. The 17's were much more forgiving when it comes to pot holes and such but the 20's feel much more secuire, not sure how to describe. I would rather invest in better tires for better ride than drop down to 17's. I think there is a difference in ride but you can minimize the difference with better tires. You will not be happy with the look of smaller rims. Even the 20's look small without a drop.
ColombiaPunk
Just got rid of the 20s on my Denali for 17s with duratracs. Looks much much better and does ride better. Soaks up pot holes like they're not there.
Costal_Cat
Funny I found this I was thinking about going to 18's with duratracs on my 2012 Denali XL. My reasons were that more sidewall means better handling on country and back roads. Also at my boat ramp at low tide, the ramp is pretty chewed up at the bottom and having more sidewall would be a good thing. Given that I do want to put the biggest tires I can on the 18's what size duratracs did you put in those 17's and did you get Stock rims or aftermarket. Do you have a picture you could post?
Thanks in adavnce!
Trailblazzin
Trailblazzin
Lancaster PA
Thanks for all the input, I do agree that the 20” wheels would look better just can’t make up my mind. I might go test drive a tahoe with 18’s
One also gives up a true off-road capability when switching to 20s and larger. The owner's manual states this. The sidewall of a tire is what absorbs the bumps in the road, along with the suspension of course. But the tire is the first point of contact and also the taller the sidewall, the more air, the more air, the higher the weight rating, generally speaking.
As for me and my house, I'm sticking with the 17s and AT LT tires until they wear out.
Your other consideration is whether or not you want a P-Metric tire or an LT tire. Better ride with the P-Metric but more durability with the LTs.
Meccanoble
Georgia
If you are doing off roading, smaller rims makes sense. In every situation, smaller rims makes sense except for looks which is subjective. Denali/Escalade is like the highest luxury of SUV in the GMC fam so I thought looks was the priority but comfort really seems to be and I respect you for wanting to obtain that by any means.
Brian1971
I guess the LTZ autoride air system soaks it up. I can't feel any difference.
K2 Kaiju
The Depths
My 2011 avy was LS with 17s. Current 2013 has autoride with 20s, and I found the autoride does even up the sidewall difference (I actually remember driving home from the dealership thinking the ltz should be more of a difference). I am positive 17s on autoride would make the ride even softer with the extra 1.5" of rubber cushion. If I off roaded more, I would consider it - ride is great right now though. 20 is good balance, and the michelins ride great...
Sent from my SM-T350 using Tapatalk
HeavyHoe03
