2016 yukon xl denali 4inch lift 4wd
Joshb0718
another question I had for you and I had a lot so thanks for responding to everything cuz I'm going to go out and do what you did did you happen to hear if there was any issues with the alignment with that one and a half inch bottom strut spacer in the front is your suburban
Yes they realigned it for me. 4wp Bought the 1.5” spacer, installed it, realigned it, all for the original price, nothing extra. Just to help fix the issue, since I asked them prior to installing if it would be level and they said yes and they wanted to help fix it.
Joshb0718
And if you ever can get a chance can you get a picture of the front CV angle I like to see how it looks thanks again
Here’s some pics
Adam10532
Adam10532
Here’s some pics
I was wonder how many miles have you put on
thanks for the photos.
thanks for the puctures
Here’s some pics
Another thing I wanted to ask was can I get a photo of your upper control arm where the Magnetic Ride is attached to the upper control arm is there a new bracket that had to be installed because of your lower control arm spacer.
Adam10532
Adam10532
I had this same issue! Looks like a leveling kit with the rear way high! I also had it done at 4wp. Fabtech also offered me a lower rear spacer, I didn’t want that since it wouldn’t give me the lift look and only the leveling look. And for nearly $4k that didn’t seem right. I had a level kit on it before and the final solution was 4wp put on the bottom 1.5” spacer from another lift and it helped even it out better. Attached is the level kit pic, 4” fabtech lift kit, and final the 4” plus the 1.5” to make it really a 4” kit. Only about another $50 in parts to get what you want.
do you have any more photos of the truck a lot more level ground so I can get an idea about the rake that it has
01Konvict
Boats n Hoes
Raleigh/SML
That lower spacer is only a 1/4" thick so it lifts a total of 1/2" on front. The other top strut spacer gives the lift. I wouldn't go any higher with that cv angle for longevity. I think the best option is to lower the rear down to match front. Still best 4" kit for a Denali is RC 3.5" with custom rods for ride height sensors or go BDS 4" with RC shock extensions to retain auto ride plus rod spacers.
Adam10532
Adam10532
So that bottom rear spacer shown above that is truly not a inch and a half thick what you're saying is it's a ratio so that quarter inch thickness added up to 1/2 inch a lift on this particular vehicle.
01Konvict
Boats n Hoes
Raleigh/SML
Yes you got it right. Its no way a 1.5" spacer because anything over 1" hits the cv axle. Anything that mounts on the bottom of the strut doubles the lift height. So a 1/2" spacer lifts 1" and 3/4" spacer is 1.5".
Adam10532
Adam10532
Man thanks for the info I'm going to do the same thing on my truck I already wasted enough money on the Fabtech lift I'm just going to put a inch in the front and put my 2-inch spacer back in the rear to get a leveled look and a true 4 in front
01Konvict
Boats n Hoes
Raleigh/SML
No problem dude. Glad to help get it sorted. I really dislike the 4” Fabtech. Hope to see yours leveled and looking right soon.
Adam10532
Adam10532
Here’s a better pic to show the gaps and it’s much better than before. Idk how anyone would be happy with the 4” kit fabtech sells as is...
can I get a pic of that upper control arm where the magnetic ride senor attaches to thank you.
Adam10532
Adam10532
Today I'm going to put a bottom strut spacer like you did on your ride but my question was how does it look on the top of your control arm is there a bracket relocating the magnetic ride sensor arm this picture I will attach circled in Red show you what I mean mine . did you have to put a relocation bracket in this location can I get please get a pic if possible
cbraga
Getting ready to do this kit myself, any updates?? More pics??
Adam10532
Adam10532
Getting ready to do this kit myself, any updates?? More pics??[/QUOTE
Now I have a 1 inch bottom strut spacer made by , supermax suspension in two weeks I'm going to have the rear 1 in spacer replaced with a 2 inch spacer to make it level .currently I'm writing one inch higher in the front now I have a true 4 inch lift in the front.
cbraga
Okay and so that’s with the budget 4” Fabtech, and a 1” SMAXX bottom spacer?? Anything new with the mag/air ride linkage? How’s it been driving?
Adam10532
Adam10532
So far it is not working with a 1-inch spacer but I also contacted supermaxx suspension and talk to John by the way .. he sold me just sold me the autoride relocation bracket appropriate for a 1 thru 2-inch spacer so I will have that installed in a few weeks I will post the pictures up when i am done but on a side note what a project this became all becaise fabtechs kit is a true 3 inch not a 4 inch as they adverise here is a pic how I got my yukon him day one
cbraga
Yeah, not a good look ass up like that. If I’m understanding you right
With the added 1” your mag/air ride is off “but” if you add the link that comes with the suspension max 2” leveling kit that “should” fix that issue?
Adam10532
Adam10532
so I saw an other member on here just a bottom strut spacer to rasie the front end up to match the rear end , but if you call Fabtech ask them to send you a 2 inch spacer because the kit will come with a 3-inch spacer from your kit and that is way too damn High considering that the front end only raises 3 inchs . i Chose just to go with a 1 inch bottom strut spacer so that way my CV angles weren't that bad as you can tell from the photo of my front axle it's not too bad... but going an 1.5 inch I would think it would be worse and as far as the ride quality it's bearable nothing intolerable does not bother me.
Adam10532
Adam10532
Is exactly correct
Drewphil
