2016 yukon xl denali 4inch lift 4wd
Joshb0718
Plano, TX 4wp not plank tx, dam stupid smart phone
Adam10532
Adam10532
what is your difference in height from the back Fender to the front fender by doing that what is your rake
Joshb0718
It’s within an inch which was better than the 2-2.5” difference at first! I’ll measure and check. Fabtech and 4wp kept telling me you have to use the body lines and not the fender gap, I feel like fender gap is what visually makes it look level and body lines are their way around fender gaps
Joshb0718
and you still have the 3-inch spacer installed from the original fabtech in the rear ?
Have all parts of fabtech 4” budget + front lower spacers. No parts were removed or swapped to accommodate the lower part added
Joshb0718
39.75” in the front and 40.5” in the rear. Measuring ground to center of fender. Not level but visually looks a lot better than the rear being crazy higher and the front looking stock/level and not “lifted”
Adam10532
Adam10532
I can't wait to do this to my suv I just had it leved by lowering the rear to a 1inch spacer man all this money wasted I have already had a 3 ,2 and now a one inch spacer
Adam10532
Adam10532
oh yeah looks real good nice job
Joshb0718
Yes it is the ltz so it has magnaride/autoride
Joshb0718
Here’s a better pic to show the gaps and it’s much better than before. Idk how anyone would be happy with the 4” kit fabtech sells as is...
Adam10532
Adam10532
Here’s a better pic to show the gaps and it’s much better than before. Idk how anyone would be happy with the 4” kit fabtech sells as is... yeah looks good and no kidding about Fabtech I feel like taking him to small claims court and get a portion of my money back cuz I got a portion of a 4inch lift
Adam10532
Adam10532
are those factory wheels and did you have to use spacers
Joshb0718
Yes factory 22” and yes spacers. Love the look of these 22” over aftermarket wheels. 4wp supplies the spacers, overpriced, but included in their warranty package incase anything goes wrong
Adam10532
Adam10532
you're so lucky your suburban looks great the stance is great and where you had it installed they work with you to correct the problem what size tires are you running did you have any trimming to do or any rubbing
Joshb0718
33”x12.5x22 nitto g2
Minor trimming I think? 4wp did the trimming, and minor rubbing on bumps with turning hard, I think that stopped once we added the extra 1.5” in the front
Adam10532
Adam10532
Yeah I could tell that was the G2 I ran the same Tire excellent tire low to no road noise excellent Road mannerisms and it doesn't look too crazy of a tread design my favorite all-terrain tire
Joshb0718
Yes sir, I wanted a Tire that was good on the road for road trips and not the added road noise that could make one regret buying the tires. Been using the g2 since they came out and the g1 “terra grapplers” since before that, no complaints
Adam10532
Adam10532
another question I had for you and I had a lot so thanks for responding to everything cuz I'm going to go out and do what you did did you happen to hear if there was any issues with the alignment with that one and a half inch bottom strut spacer in the front is your suburban
Drewphil
