DallasTahoe
Picked up a new (used)front Diffy to replace my wore out and noisy one for $95
Creese99
Ocala Florida
@Creese99
What brand paint and color did you use for those back trim pieces above the tail lights?
It covered it really well. Good paint. On metal and plastic. Got it at o'reillys.
I put that sh*t on everything!
Creese99
Ocala Florida
Hey thanks, I'll take a look at it. Just noticed that mine are peeling. Did you have to prep the surface or anything?
It's a good quality semi flat. Yeah I did prep it. Sanded it with 320 grit I believe, then a 600 grit. Then wiped it down with alcohol. Make sure you sand the spots that have peeled really good, or you'll be doin it again like I did. Did the same thing with the frame and wheel wells.
scotto0609
Finally got around to putting variable steering gizmo in and cleared up all my steering issues! Local garage wanted to change about all the front end out to the tune of @ 1000. I hate people!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Backed out screws again on my msd rotor inside my msd dizzy. 3 hr's for a tow truck. This time it stayed in place for 4 years as opposed to 1 at the first break down. Like before replaced broken parts and it is back to normal. Should probably inspect it every few years from now on.
east302
Mississippi
Wow. Is there a manufacturer defect that causes that?
W8TVI
Traverse City, MI
I did the 4-high mod on my dads '98 Sierra, and my 2000 Yukon XL (GMT800).
I know that they aren't a GMT400 Tahoe or Suburban, but I though you guy might be interested anyway, as it was a super simple mod if you have a relay kit for your headlights installed already.
Both our trucks have an aftermarket headlight relay kit installed, so it can run the 4-HI mod with out taxing the stock wiring.
Because both trucks have the aftermarket relay kit, it was VERY easy to do the 4-Hi mod.
On my Yukon XL, I only had to jumper from ground to the low beam trigger/input ground wire.
On my dads truck, I needed a diode and I ran a wire with diode in to from the high beam trigger +12 wire to the low beam trigger +12 wire (cathode (the stripe) of the diode pointing to the low beam wire). If we hadn't had the relay kits, we would have had to use a relay instead of a diode to run the low beams on his truck.
I would recommend the relay kit as the headlights seem brighter being ran directly off the battery/alternator.
beerme
GA
Finished full front end rebuild last week w/ all Moog parts, rebuilt P/S pump and bypassed EVO and topped it off with a Redhead steering gear. Changed front/rear diff fluids. Detailed the exterior.
Next up is cleaning the evaporator and changing out the belt, tensioner, and idler pulley so I can get a bit of my sanity back.
Danny3737
Krylon makes the best paint. I wish Lowes or HD sold it
SunlitComet
OBS Jedi-Do Good
Unfortunately I think it just a vibration issue and a little rusty issue over time. The screws from msd or even delco caps/rotors comes with what appears to be thread sealant on them to help keep them in place. In the msd dizzy the rotor mounts on metal plate and actually have maybe 3 complete threads tops. Over time that sealant just disappears and things get a little rusty in there so they work loose. Vibration in certainly does not help. I am trying blue threadlock this time since the both screw sets are torx bits and are hard to strip out. The cap ones have never backed out before but then threads go all the way in the dizzy with none exposed on the other side. The rotor plate could stand to have more bolt grip length.
kwOH
Banned
Pulled the side steps off the burb. Love the look but hate that you can see the frame
Super clean. [emoji106]
Sent from iPhone 7 plus using Tapatalk Pro
jiggie
Thanks! It will look even better when it comes home from the body shop. Goes in tuesday to get repainted from the vandalism.
edonwheels73
Just drove it and checked fluids added some bars rear main repair and half qt transmission fluid.
Sent from my SCH-I545 using Tapatalk
jiggie
Dropped it off at the body shop and picked up the rental. Going to be spoiled driving the 17 burb.
JeffK
