Kbkiller
- Joined
- Feb 15, 2017
- Posts
- 49
- Reaction score
- 27
Hey what's up everybody? I figured I should start a thread on what I'm doing with my yukon.... So I was at 3/5 for 2 years with norcalss kit and was debating on leaving it there and doing 24's but I wanted more low. I thought I had a great deal on these same wheels in 24s but that fell though so I decided 22s and lower! I bought belltech 2in drop spindles a few weeks ago and finally had some time to get everything put together.
Specs
04 yukon denali xl awd
22" gm honeycomb reps with 285/45 22
Front
Stock upper arm
Djm 3" lowering lower arm
Belltech 2" lowering spindles
I think it was a djm sway bar bracket but the bolts broke so I'm going to try all tread
Shocks are belltech street performance
Moog everything else
Djm track bar relocation brackets
Djm sway bar relocation brackets
Norcalss custom 6" springs with a half coil cut out
The back is pretty straight forward I just took out the 1" spacer and cut a half coil out to get about 7"
And to go that low I just flipped the upper shock bolt and I'm in the process of deciding about trimming the inner plastic fender or using a heat gun to mold the plastic
MORE PICTURES OF THE WORK TO COME!!
The front
When lowering an awd this low you have to trim the upper ball joint right under the castle nut to clear the cv axels
The djm lca makes contact with the belltech spindle so just minor trimming is needed. I have before and after pictures I'll post later.
The drivers side I took out the lining and started trimming and that's where I finished today.
I'll post pictures in detail on what I'm doing to fit this big rubber this low.
The real problem up front is at full lock the inner cab area is tight( duh)
Driver side will be easier, I hope, because there is just some break lines and wiring harness to move out of the way.
The passenger side is going to be a pain in the ass because gm ran the rear A/C tubing right where the tire isn't happy!
More pictures and progress to come!
Specs
Front
Stock upper arm
The front
