Finally got 5/7 on my Denali
Kbkiller
Hey what's up everybody? I figured I should start a thread on what I'm doing with my yukon.... So I was at 3/5 for 2 years with norcalss kit and was debating on leaving it there and doing 24's but I wanted more low. I thought I had a great deal on these same wheels in 24s but that fell though so I decided 22s and lower! I bought belltech 2in drop spindles a few weeks ago and finally had some time to get everything put together.
Specs
04 yukon denali xl awd
22" gm honeycomb reps with 285/45 22
Front
Stock upper arm
Djm 3" lowering lower arm
Belltech 2" lowering spindles
I think it was a djm sway bar bracket but the bolts broke so I'm going to try all tread
Shocks are belltech street performance
Moog everything else
Djm track bar relocation brackets
Djm sway bar relocation brackets
Norcalss custom 6" springs with a half coil cut out
The back is pretty straight forward I just took out the 1" spacer and cut a half coil out to get about 7"
And to go that low I just flipped the upper shock bolt and I'm in the process of deciding about trimming the inner plastic fender or using a heat gun to mold the plastic
MORE PICTURES OF THE WORK TO COME!!
The front
When lowering an awd this low you have to trim the upper ball joint right under the castle nut to clear the cv axels
The djm lca makes contact with the belltech spindle so just minor trimming is needed. I have before and after pictures I'll post later.
The drivers side I took out the lining and started trimming and that's where I finished today.
I'll post pictures in detail on what I'm doing to fit this big rubber this low.
The real problem up front is at full lock the inner cab area is tight( duh)
Driver side will be easier, I hope, because there is just some break lines and wiring harness to move out of the way.
The passenger side is going to be a pain in the ass because gm ran the rear A/C tubing right where the tire isn't happy!
More pictures and progress to come!
shakedown067
YES, YES, YES! Looks killer.
Man, I'm rubbing at full lock with a 3/5 on 285/45/22s. I was going to go 275/40/22 but got a deal I couldn't pass on these tires.
That looks awesome but no way is that 5/7. Did you take before/after measurements? I have a 2/3 on mine with 26's and yes you will have to do some work in the front in order to turn good, and you'll still get rubbing in certain situations. The inner fender wells are just the start! Some metal work will be necessary as well as rolling the front fenders or you'll pull the inner fender lips down if you hit a bump just right, probably going in or out of a parking lot/ driveway at an angle or dip. I did it and got lucky it was easily fixed. Good job though!
Kbkiller
Kbkiller
That is looking good. Makes me want to go even lower from 2/4.
Good luck working around those lines.
Thanks man! I think the lines will only be a problem if I'm turning on a speed bump! Only time will tell on what more is needed so I don't tear stuff up.
Thanks! No I didn't take before measurement but I'm just going off of what I installed. I just finished it a couple hrs ago and drove it around my neighborhood and with big dips, no rubbing on turns going 15mph it's going to be at hwy speed where I think I'll find more problems.
NORCAL SS
SUV SUSPENSION GURU
pm me if you want to fix the rear end position. looks like it got sucked forward a lot and ive had a few guys bust the output shaft since driveshaft gets pushed into trans being so low
Kbkiller
Kbkiller
this is the lca and spindle where it had to be trimmed. It's rough I need to get more discs for my grinder. After I clean it up I'll throw some paint on it to stop the rust until I can powder coat everything.
this is the driver side where it had to be trimmed and hammered smooth. I'm Still trying to figure out the best way to fill in the gap.
This is the passenger side and this is what the driver side looked like before the trim and you can see why I had to. That flap of metal is just waiting to get caught up in the tire. I will do the same thing to this side when I get more disks.
In the process of adjusting the 3/8s all thread for my sway bar.
The emergency brake line went through this body mount so I just pulled it apart and went around it. There are to places that stick out that had to be trimmed, 1 on the Frame above that hole and 1 on the top body mount. I still need to pretty it up and paint. When I figure out the gap issue I will tear everything apart and paint and powder coat everything.
I'm still debating on getting the djm uppers now or waiting until I figure out what direction I'm going(static or bagged) because it will be my wife's daily for a while.
I will update with pictures when I get everything buttoned up.
NORCAL SS
SUV SUSPENSION GURU
No need to trim. So my fender well mod in front will be fine
Pachanga02
Ny
Makes me want to lower mine a bit more sooner. Everything is just sitting in the garage waiting to be installed. Looks great
Kbkiller
Kbkiller
Thanks man! I know the feeling I was collecting parts for a while before I pulled the trigger. If it's your daily make sure you aren't missing anything :grd:
This thing is gorgeous. Sitting just right
Thanks man I am happy with the way it's turning out. I think I'm going to get it to a point of minimal rubbing and no frame contact and roll static. Well let the wifey drive it.
Looks good
:beer:
TheAutumnWind
Allthread sway bar links? Have you considered using pipe or something to sleeve the allthread and aide in strength?
Is this way less expensive then off the shelf links? I would think not really if you are using grade 8 hardware.
Also... it looks bitchin'
Thanks for sharing all your work!
Kbkiller
Kbkiller
I love the look of those chrome snowflakes on a sharp NBS truck like yours!
Very nice look!
I want to get a set for my Yukon XL.
Thanks man! I've always loved the look of these wheels and finally pulled the trigger. They aren't chrome though they are machined silver.
I appreciate it! I'm not sure about off the shelf end links working with the lca that I have and I already had the all thread sitting at the house. I am going to get something to sleeve the all thread eventually but right now it's worked great for a few thousand miles! The links that I had actually bent and I think they were grade 5 bolts.
Antonio Estrada
Fort Worth Tx
Thank you now i know whats next for mine but ima end it by going 5/9 but ima need all the rear hardware from tony if i wanna do that Finna start saving!my denali needs that low low life
varminpoolteam
