Get a catch can before any mods.
Drok
Cold place in the north
Im Casper and Im new to this forum. An I wanted to if I could install one on my 99 tahoe?
Of course, I don't see why not. I coldnt tell ya where it's located since I've never done one on a 99 but I'm sure its pretty close to the same as these one. Someone with more knowledge of this should be along to really help..
Casper1213
Alright thank you sir. Im just trying to do everything and anything that i can. For my truck cause she has 257xxx miles on her.
mdhawk
Reading, PA
I just put mine on tonight. I got it from catchcans.com. The 90deg fitting on the top of the can goes to the line out of the valve cover( driver side against the fire wall). The fitting on the side goes to the top of the intake. You can trace the line out of the valve cover to make sure your using the correct one.
NGAneer
NWGA
I took my throttle body off and looked inside my intake and I wish I could get it clean in there. I'm hoping sea foam will work. It's worth a shot I guess.
Broom handle and old t-shirt. Did it on my 99.
Dempski13
Got mine on aswell, ended up picking up a Burger tuning can(for a Beamer), found it on KIJIJI. Made a custom bracket and reduced down from 3/4 to 3/8 lines.IMG_6760.JPG IMG_6761.JPG IMG_6759.JPG
JRSB16
