Looks good! Nice and clean.
Thank youLooks good! Nice and clean.
I'm glad it did too. Other than the old carpet being used again for a while longer, I'm pretty happy with how the floor turned out.Came put clean and flush . Glad I was wrong on my assumption![]()
They are glued to the carpet, but they clip onto the little metal bars that the seats are supposed to lock intoAlso forgot to ask , were your trim pieces glued in or clipped in? Mine were glued to the carpet and didn't really clip in.
Looking good. What's that in the upper center console bezel? Where the cubby used to be, under the power points.
Nice work!
Those speaker tweakers legit? I've never used them
Careful with 50w in those fog housings. But I might just be paranoid too. My 35w hids haven't melted mine yet.
Damn brother, just read the entire build...awesome work! You're the perfect person that should be able to answer my question regarding stereo installations. I have to run 3 rca's and 1 remote wire from the hu back to the amps including 4/0 power and ground cables. I plan on running the remote/rca's on the passenger side and the power and ground on the drivers side
I bought these rca's... KnuKonceptz Krystal Twisted Pair 2 Channel Smoke RCA Cable 20ft 6M OFC | eBay but they're as thick as 4/0 wire! My system will consist of 2- 1000 watt 10'' rockford fosgate subs and 4- 90 watt 6.5''watt rockford forget door speakers, 1- 2000 watt mono amp for the subs and 1- 500 watt amp for the door speakers...nothing nearly as crazy as yours lol
Are those rca's overkill? or should I just run normal sized rca's since they won't fit under the floor trim?
