07+ Brake upgrade on a 00-06 NBS, is it worth it?
ScottyBoy
Shreveport, La
For those of you who upgraded your 00-06 Tahoe/Yukon front brakes to the larger 07+ style front brakes, is it worth it? I want farbetter braking than I have now on my 01, and I'm wondering the best way to go about it. Will the 07 brakes stop my truck faster? I'd like real reviews from those who have actually done it. Or should I save up my cash for a big brake kit (which I'll probly never be able to afford anyway)??
I currently have Power Stop drilled and slotted rotors with Wagner Thermoquiet Ceramic pads. They stop a tad bit better than stock, but I need to stop my truck faster. Especially if my wife is driving it, LOL.
Rivieraracing
Scottyboy, I have all the parts to do this conversion......but I have to find the time to actually swap it out! When I get a chance to do them, I'll give you may opinion!
S
ScottyBoy
Shreveport, La
Thanks Chris. Let us know how it turns out. Whether its a week or two from now, or 6-8 months from now please keep me posted.
I read about people doing this conversion all the time, but nobody ever states how much it actually improves the braking. Yeah, if your brakes are worn out and need to be replaced anyways, I'm sure there will be a HUGE difference in the way it stops. But if you already have good rotors and pads like I do, will this mod REALLY make much if any difference in stopping power and/or stopping distance ??
Rivieraracing
Sure hope it doesn't take me "months" to get around to it......but I wouldn't be surprised if it did! lol
And to mention, I have an all OEM braking system so I would see way more benefit than you would but will still check back in when I get around to actually doing the swap!
Sub'd. I also recently installed drilled and slotted rotors, so it's hard to justify the upgrade.
Fosscore
Interested in a review with them on. Also put the Powerstop drilled and slotted rotors and new pads last year, so can't justify the upgrade unless it really is night and day.
TheAutumnWind
I have read subjective reviews stating that there is a noticeable difference.
http://chevyavalanchefanclub.com/cafcna/index.php?topic=122524.0
I plan to do it when I wear through my fronts.
Might be worth going with the police package:
http://www.rockauto.com/info/Raybestos/PoliceBrochure.pdf
Finally got around to finding time for the Upgrade...........have to say the difference is night and day! Fantastic upgrade! Couple of pics; but due to time constraints, painting the calipers was not an option......
OEM GMT800 setup:
GMT900 update:
Many thanks to everyone that contributed to this post! Highly recommended!!
1992rs
OR
I did the upgrade. I used R1 premier slotted rotors, ac delco front calipers, hawks lts and goodridge ss lines. It is much better than what it is was before but I am also on stock 17's, I have no way to quantify it other than the seat of the pants/pedal travel feel and I now want bigger sway bars to control the nose dive when traffic just decides to randomly stop.
I wish I could tell ya what made the biggest difference, whether its the 1in extra mechanical leverage from the rotor and the beastly calipers, the pads or the ss lines.
I would try the ss lines first and if you aren't satisfied then do the nnbs upgrade. Theres always hydroboost as well
Sasquatch
Orange County N.Y.
When i upgraded i went with R-1 E-line slotted and drilled rotors and SS lines too and i think it made a big difference. I never really had a reason to slam on the brakes with them installed until a few months ago when i was towing my 6x12 trailer with my yamaha rhino on it going about 75 when the traffic came to a sudden stop from an accident. I was behind a tractor trailer so i couldn`t see brake lights in front of him and i`m sure that with the stock brakes i would have slammed into him but i easily stopped with a few car lengths to spare.
TheAutumnWind
Worth every penny then
pnwdan
Cunning linguist
Arlington, WA
I haven't done it but my co worker has a 2000 Suburban 1500 he tows a trailer with and I told him about the conversion so he ran out and did it that weekend. he said its a big difference.
Pachanga02
Ny
I did it years ago with my stock wheels and noticed a difference right away. I already had newish pads and rotors but couldn't pass the deal I got on the new combo. I only had stock wheels at the time and driving in traffic I felt it grab faster then it would have with my old setup. I'd suggest it.
lowAZhoe
Resident GM Tech
Phoenix, AZ
I did it. It's a little better. But not really noticeable. I now have a brembo kit that uses stock caliper with larger rotors and that really made a big difference.
Fosscore
@lowAZhoe
You have more details on the Brembo rotors using the stock calipers?
Definitely applicable whatever you can share for those of us on the fence with trying to gets the beasts to stop. Thanks man.
khaled_94
im wondering since the front GMT900 is 13" with single piston and the rear GMT800 is 13" with dual piston
can i just install the front GMT900 Rotors instead of GMT800 rear rotors?
cuz in my area we have gmt900 spare parts more than gmt800
pnwdan
Cunning linguist
Arlington, WA
@lowAZhoe
I believe you can order a similar SSB kit from summit
lowAZhoe
Resident GM Tech
Phoenix, AZ
Fosscore I don't think brembo makes it anymore or at least that I found. But Baer makes a kit that is similar. It uses a bracket to use the stock caliper on a larger rotor.
I originally swapped brakes off a 2007 escalade. It had drilled and slotted front and rear stock replacements. I knew the front was a direct swap. But the rear didn't work. The NBS backing plate is bigger than NNBS. I would of had to trim them or take them off. And for really no gains it wasn't worth it. And if I remember right the NBS is double piston and NNBS is single. So I left the rear alone. The braking was slightly better. But looked better due to their size. A friend was trading his 02 Silverado in and it had a brembo kit with rear rotors to match the fronts. So these brakes really stop when I ask it to. Plus I have hydroboost and stainless lines. The lines made an improvement. Less spongy.
I don't think the swap for NNBS is worth it though. Unless you have the parts for free or very cheap. And they are only slightly bigger.
I understood the mod is actually to install GMT900 (07-14) front rotors and calipers/brackets on the front of a GMT800 (00-06) truck.
BadDaddy2003
