Yukon 2000 parking brake cables
Kazap
ST SAUVEUR QUEBEC CANADA
Hi everyone happy new member first try. I am french speaking so excuse any mistake. I need confirmation of parking brake cable routing especially from left back plate returning toward front at differential. Originally no cables present. Thank you
Envoyé de mon iPhone en utilisant Tapatalk
K
Kazap
Both cables below differential
^^^ and the cable coming from the right side usually goes under the sway bar, also your sway bar looks really out of whack, when the vehicle is sitting on the ground, the sway bar should be straight in-line (level) with the frame, not pointing up
K
Kazap
Thanks for info. Yukon resting on four supports rear end not touching ground.
BlacktopBandit76
