Both cables below differential
Thanks for info. Yukon resting on four supports rear end not touching ground.^^^ and the cable coming from the right side usually goes under the sway bar, also your sway bar looks really out of whack, when the vehicle is sitting on the ground, the sway bar should be straight in-line (level) with the frame, not pointing up
