Yet another lift question
brknhal0
Hi All,
Thanks to all the posts from the members on this forum. I have learned quite a bit from all of the posts on the differing levels/lifts that are available and the before and after pictures. After researching all of these posts many, many times, I have decided to go with the SuspensionMaxx 2.5 inch in front and 1 inch in the rear. From what I have seen, this will level my 2015 Tahoe LTZ nicely while giving it a little bit of lift overall.
Although there are many differing tire sizes listed in these threads that I can use as examples, I was wondering if someone has installed the Ridge Grappler 35/12.5/R22's. If so, has there been any rubbing that was compensated for due to the width of these tires?
I am confident that the 33/12.5/R22's will easily fit as well as 295/55/R22's.
My desired end result is to fill up as much of the wheelwell as possible without having to do much trimming. Keep in mind that I will be cutting the front Mack-Truck-Looking air dam to look like the ppv air dam.
Thanks in advance for the input.
olyelr
Elk Rapids, MI
Ridge grapplers dont have 295’s in the 22” wheels. However, the 285/55/22 is the same height as the 35”, yet an inch thinner. I would highly recommend that size over the 35”.
Just turn your wheel and look how close the stock tires are to rubbing. A 2 1/2” level really wont gain you anymore room for a wider tire... you will still be very close to rubbing that same spot.
olyelr
Elk Rapids, MI
These are 285/45/22 nitto’s on my wifes rig with a 1.5” level. I cant imagine a tire that is another inch wider would not rub, even with another inch of lift.
It would surely be very close.
Robbys3m3
I cant wait to see the results here...ive been wanting to do trimming and go taller than our 285/50/22, but haven't gotten to it.
griffey_mojo
