Will a 20" Wheel Spare Fit Under the 2016 Tahoe?
ATX 14
I'm running 20" wheels on my 2016 Tahoe and would like a spare to match my wheels that are currently on the Tahoe. Will a 20" rim/wheel fit under the Tahoe? If so, are there stock 20" steel rims out there? I'm not up to speed on what size spares are available with different models. Thanks for any information.
Big Mama
Virginia
I’m not sure about the ‘16 model but I had the same question for my ‘07. It came down to if it fit in the hole for the spare it worked. Most spares are 17” but the bigger question is overall circumference of the tire. If the spare is close to your 20” set you’re ok to put it on until you get your 20” fixed. If you’re looking for a 20” spare just get an extra of the other 4 and rotate it in with the others.
zbad55
Detroit
2016 Tahoes were avalible with 20's so just follow the size of the production tire sizes and you will be fine,
07 Denali
I have a 20” wheel under my 2018. It is a little wider of a tire so it doesn’t tuck up as nice as the OEM spare but it will work just fine.
Ihaveatahoetoo
