Where is the RCDLR located in My Truck?
It looks as though I need to replace my Remote Control Door Lock Receiver (RCDLR) module on my 2007 Yukon XL Denali, and I'm having a challenge to find out where this module is actually located on my truck. I've searched around, and I get different answers on where it may be located.
Any tips that will help me find this module will be very much appreciated.
Moderator
People's Republic of Colorado
FWIW diag procedure here:
Location here (see the last two in the graphic, depends on RPO code).
Be careful with messing with this, make sure you remove ground post before touching. I have had a hell of a time getting mine working again, DO NOT BUY THE UPGRADED PART NUMBER THAT SAYS IT WORKS. you will also have to have the module programmed after its installed. i found a dealership for $190 to do mine.
Hi Folks,
Update.......
Doing more troubleshooting work, I found the source of my issue, and it was not the RCDLR, and as such, I do not need to replace it. I do appreciate all of the comments and suggestions, however.
And, yes, I was prepared to program the replacement module, as I have both a Tech 2 and an Autel MK900-BT scanner.
Foggy
KS
Hi Folks,
Update.......
What was the issue ????
What was it?
Right rear wheel sensor.
The strange part is when trying to do the learn process, I could not even get past the front left wheel sensor to learn. And, neither of my scanners pointed to an issue with one wheel sensor, or I simply may not have dug deep enough in troubleshooting with the scanners.
26AT4
