Where is the RCDLR located in My Truck?
It looks as though I need to replace my Remote Control Door Lock Receiver (RCDLR) module on my 2007 Yukon XL Denali, and I'm having a challenge to find out where this module is actually located on my truck. I've searched around, and I get different answers on where it may be located.
Any tips that will help me find this module will be very much appreciated.
FWIW diag procedure here:
Location here (see the last two in the graphic, depends on RPO code).
Be careful with messing with this, make sure you remove ground post before touching. I have had a hell of a time getting mine working again, DO NOT BUY THE UPGRADED PART NUMBER THAT SAYS IT WORKS. you will also have to have the module programmed after its installed. i found a dealership for $190 to do mine.
Hi Folks,
Update.......
Doing more troubleshooting work, I found the source of my issue, and it was not the RCDLR, and as such, I do not need to replace it. I do appreciate all of the comments and suggestions, however.
And, yes, I was prepared to program the replacement module, as I have both a Tech 2 and an Autel MK900-BT scanner.
Foggy
KS
Hi Folks,
Update.......
What was the issue ????
What was it?
Right rear wheel sensor.
The strange part is when trying to do the learn process, I could not even get past the front left wheel sensor to learn. And, neither of my scanners pointed to an issue with one wheel sensor, or I simply may not have dug deep enough in troubleshooting with the scanners.
Tupapi
