What's the "right" way to kill rattles?
SnowDrifter
Sasquatch Country
If this is a dumb question I apologize. Interior work isn't something I frequent
15 year old rig w/ 140k on it has developed a few interior rattles/buzzes over the years. I want to get her back to "new car" quiet. In particular, where the gauge cluster secures to the dash support, and my driver's side C pillar panel. There might be a couple others but those are the worst offenders. One makes a racket when I go over bumps, the other buzzes at 1100rpm on a cold start.
What's the most appropriate way to fix the stuff? Butyl? Tesa tape? Replace clips? Heat and reform the plastic? etc etc.
Erickk120
I have a few my self, I've thought of 3m double sided tape, or something of that nature to pad the plastic in the weird spots. Those in the cluster vibrate just at the perfect frequency to annoy me. Let me know if you find a good cure.
Big Mama
Virginia
Same here with padded tape or sometime Velcro as it works as tape and pad in one and it’s removable. Might also be worn holes vs loose screws so next size up helps too.
I think the fix would depend on what is causing the problem. As manufacturing technology advances, the tooling and molds are able to make panels more precise so the gaps are smaller than in older cars. But, plastic is still plastic and it will deform over time with exposure to sunlight, temperature swings and other environmental factors. So, it will loosen up where it's mounted and relax/settle where it's not so supported.
If the problem is a loose mounting point, such as where the plastic tab of a trim panel snaps into a metal hole in the body, I'd tighten up that connection rather than try to brace the entire panel elsewhere. I was installing an iPad mount into a new (at the time) 2010 Sierra Denali and noticed each of the holes in the dash where the bezel snapped in had felt tape surrounding it. Having ripped apart the dash on my S10 and other similar-era vehicles, that was something new to me. A simple but effective solution that the factory took the initiative to install. You could do the same with your trim panels to tighten the hold and insulate the parts from each other. Just get some felt tape with adhesive on the back side, cover the hole and cut a slit in the middle of it with a razor (an Xacto knife would be ideal) for the trim panel's tab to go through.
Using felt buffers such as what Wes linked to would be great for the areas where a panel rubs and makes noise. Some points need to flex independently of the parts they're attached to, so trying to "glue" them down to those parts won't work. Instead of trying to secure them, just insulate the contact point with felt so the panel can rest on in and move as needed without making any noise.
Way back in the day, with my Civic and S10 (both had decent sound systems with big subwoofers), I played bass notes from an Autosound2000 CD to make the interior panels rattle and buzz. Different bass frequencies resonated with different panels and made them vibrate. I started with the lower frequencies and addressed the rattles and buzzes as the occurred. Of course, the mid- and upper-bass coming from the door speakers revealed all kinds of buzzes from the door panels. This made sense since it was a giant piece of plastic snapped onto a metal door that was slammed thousands of times throughout it's lifetime. Replacing the "Christmas tree" pins with fresh plastic ones and insulating the holes in the door which they snapped into alone made a huge improvement. I also superglued small blocks of foam rubber behind the lock and latch rods to keep them from vibrating against the metal door frame and applied felt tape along the door frame frame where the edge of the panel contacted it.
corvette744
2004 Z-71
Northern illinois
I use a business card-can fold it to any size in seconds no mess.Fixed 2 rattles in the dash and glovebox with this method.I think anything would work jammed in the space were its coming from
Merc1973
Maryland
Took me forever to find out the 2 rattles in the back of mine. The loudest was my kids safety seats when they are not sitting in them. The other was my rear hatch glass with a broken off hinge. I JB welded it but it came loose again.
CJ Rodarme
Kent, WA
Personally I just turn my music up until I can't hear all the things wrong with my rig :D I would definitely check all the tweeters, and the little things in the headliner, which are notorious for buzzing. I know mine do, but I don't care enough to fix them. As noted before replacing clips as well as using padding (I'd personally recommend sound deadening if it works for that application) should take care of anything rattling in plastic. I would definitely do new clips + foam on the C-pillar.
mountie
My dashboard rattles a little bit, at the windshield..... I don't know yet how the dash is mounted, so I put a length of rubber vacuum hose between the windshield bottom and leading edge of the dash.
It works, I don't like band aids..... but it works.
adriver
There are clips under the dash that allow you to screw it into the metal brackets. They are known to break, that's my guess. Really cheap to fix, but a PITA to take all the dash off to do it.
Musicars
I read that wrong. I was going say get a mongoose!
I have used the peel and stick rubber feet or foam feet. The rubber feet are thicker and compress less so they put more pressure between the two pieces.
mountie
Uh, yup...... ( My ol' friend - Tom )
05Single
afraid of the dark
Little late to the party as usual .
I have a roll of duct insulation with adhesive on one side ($12) . I’ve sound deadened all my doors with it (about 2 rolls) and it helps a lot. I have some left over so if I have any rattles I can always cut off a piece as needed to stick in or wedge between whatever if rattling or rubbing.
Drewphil
