You can try tooth paste method or wet sand and reclear
Could you post a picture? "Hazy" is a vague term, is it something bonded to the paint on the rim, or severe minute scratches in the CC?
Since they are clear coated, you polish them with normal car polish and treat them just like a painted body panel.
We offer a handful of different polishes for this application. Are you doing it by hand or do you have access to a machine polisher?
unfortunately by hand - do you have something you'd recommend? - thank you very much!
Im curipus what makes you say that your wheel is clear coated?
Those do not appear to be clear coated, they are high polished aluminum, I believe. If so then a metal polish should remedy the hazing (which appears to be swirls from scrubbing, maybe? Hard to tell in the photos), I use Never Dull.
Could you confirm what that wheel came off of? I can run the VIN if its the stock wheel off of that Tahoe in your avatar/photo... One thing is for sure, you'll wanna start with the least aggressive (and most appropriate) method possible...
