What is this plate on my oil pan???
kbuskill
kbuskill
NE. FL.
I did some searching online and it is acctually a cover plate. If you want to remove it and install the part it is part number 121G on O'Reilly website
That is hilarious... I never even went to O'Reillys website earlier... I just assumed you had actually found it.... Lol
Good times.:cheers:
Kenny D
Crosby, Tx
What is located exactly below this plate? Steering? Crossmember? I still think it is a roadkill protection plate.
Kenny D
Crosby, Tx
After doing some extensive research, that plate was the brainstorm of the lead engineer at the GM headquarters. He incorporated it into the pans of the majority of the NNBS engines to:
1. Make GM owners think that they can access the oil pick up tube.
2. Make GM owners remove 3 of the bolts before they realize that it does not detach.
3. Make TYF members create a thread on said plate.
4. Make a particular TYF member (me) give this stupid answer just to bump this thread for Brian Wilson's amusement.
cmc76
looks to be the right size and shape as an insurance card holster.
with shimming could also hold a " batteries plus rewards card"
Jimmiedoss
Just for the record it doesn’t even give you access to anything.... cover plate that covers nothing..
Floep
There are vibrations in flat surfaces that lead to metal fatigue, in turn cause cracks to appear. Theory harks back to my aeronautical engineering study days. Change the mass, change the frequency out of danger range.
Yeah, I guarantee it has a purpose. It’s just that no GM engineer has let us know what it is.
I believe it has to do with something along these lines. The oil pan is a structural part of the block and that is a rather wide plane for cast aluminum to carry harmonic loads. Making that part of the pan thicker would've just changed the resonant frequency, maybe even making it more brittle. A simple plate adds strength, but, more importantly, it's bolted at various points so the plane is disrupted and waves are dispersed and absorbed. It's the same effect as how tiling sound absorption mats is as effective or more effective than just covering the entire panel.
Bill 1960
Testing the Limits
Re the dash, Based on my experience in the corporate environment, it was GM accounting and procurement that bought cheaper resins after the engineering tested quality materials. The left hand never knows what the right hand is doing. Worse, they don’t give a damn as long as it lasts through the warranty period.
Efingee
I am curious what this plate is on the oil pan of my 5.3L 2008 Suburban LTZ 2WD.
At first I thought it was some kind of inspection plate but from looking at pics of the inside of the oil pan it doesn't appear to have a hole behind it.
So is it some kind of "skid plate" or is it some kind of reinforcement for the cast aluminum pan? Or???
Just kinda curious if anyone knows.
Aluminum is non magnetic. It you live in a cold climate and want to connect a magnetic pan oil warmer then I assume the plate would serve just that purpose.
brice715
