Vibrates
captdbg
Dripping Springs,Texas - Puerto Vallarta,Mexico
Hi have a 17’ GMC Yukon Denali with 18000 miles On a trip last week it started to vibrate and feel like your running over small speed bumps every 15 seconds between speeds of 35 and 75 mph Tires look ok gonna get them rebalance in couple days Was wondering if anyone experienced this Thank You
Lots have experienced this. It's an issue with the torque converter. I believe the first crack at it is to replace the fluid and update the TCM programming. If the problem persists, they replace the torque converter.
cardude2000
How’d you end up?
Adam10532
How’d you end up?
. I believe it's more of a hit-and-miss type deal my Yukon Denali 2016 is currently in a dealership right now they replaced the fluid and reprogram the trans for the same problem I literally pick it up this afternoon I'll write back with my experience if it worked
Big Mama
Virginia
It’s under warranty take to the dealer. I believe even the tire balance is at this point.
Adam10532
I have done the transmission flush as well as the reprogramming of the transmission my problem persist
Tahoe14
Central Fl
Adam, According to the TSB a new Torque Converter would be next step and finally a new tranny.
jennifer_w
Can someone help, My tahoe shakes like crazy when I apply the breaks.. Which part needs replacement......
PLEASE HELP
Drewphil
