Trying to diagnose a top of the engine oil leak
2K8Lade
I've been trying to fix an oil leak on my 2008 Escalade. Looks like it's running down both side of the block and leaving a lot of oil on the ground.
I have already done an oil pan gasket due to replacing the oil pickup tube O ring, the oil cooler block off, and the oil pressure sending unit. The OPSU was not leaking but was bad. Valve cover gasket area is dry on both sides. Doesn't appear to be a main seal.
I used a mirror and it looks like the leak is coming from just under where the oil pressure sensor is. Is this the valley plate or what else could it be?
Thanks
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Very could well be the valley plate, how many miles on it?
2K8Lade
In case anyone stumbles on this, it looks like it was the valley plate. I was able to take some of the cover bolts out with my fingers! The gasket material was rock hard and the orings had to be chipped out of the grooves.
As a side note I found some cracked PCV boots so hopefully that helps the rough idle.
89Suburban
SE PA
Check the rear crossover steam pipe block off gaskets too and do the oil pressure switch and screen while you are in there.
89Suburban
SE PA
Maybe even that from crossover pipe too looks a bit rusty. Valve cover gaskets don't look all that well either. Good job man.
wjburken
Eastern Iowa
There have been a number of posts here where the valley plate bolts are loose. Not sure if they had wrong torque specs at the factory or what.
89Suburban
SE PA
IMO it's a combination of aging gasket surfaces, vibration, oil pressures in the VLOM unit and ports, solenoids etc. Maybe leaking VC gaskets speed that process up? Certainly stands out as an issue on these. Not only does it start leaking externally but internally as well. I had a very noticeable difference in smoothness and power with thee new VLOM installed.
2K8Lade
The gaskets were in awful shape. Very hard and brittle. I'm guessing as they age they shrink and that reduces the tension on the bolts.
It has overheated once when a heater core hose broke off on the interstate so maybe that was a contributing factor.
John H Daniel
Following this as I have similar leaks. In my 2011 Denali w/ 192k miles.
Tried a suggestion I saw on Youtube; you can reach under the front of the IM and feel 2 of the VLOM bolts. Mine are loose, so makes the decision anyway to pull the IM and replace gaskets and oil pressure sensor, etc.
Maximus05Escalade
Thanks
For sure could be valley pan gasket. do the knock sensors and harness while your there. Valve cover gaskets and intake gaskets too.
BlacktopBandit76
