Transmission Slipping P0894
latvius
Ariton Alabama
Started getting error code P0894 and when I checked the fluid is was way over serviced as in about 2-3 inches above the full hot mark that and it was a pink color on the white rag not red. Also the trans temp was higher than normal. So I figure the radiator is leaking into the transmission at the cooler/heater. When I dropped the pan this is what I found at the bottom and stuck on the filter inlet.
(Picture is of the reddish abrasive looking material, it's set on a manila folder with sawdust all around so ignore the sawdust)
So I guess this is part of some kind of clutch pack?
latvius
latvius
Ariton Alabama
No the gasket is in the pic and it's whole, the trans is 3 yo about <15k miles and I installed it.
latvius
latvius
Ariton Alabama
I thought maybe that debris was coming from the radiator/cooler but I found some pieces that are larger than 3/8" the size of the tubbing lines so that theory is out.
Cort84
