so this morning i am going to work. start truck. notice abs light on. i did see this on yesterday when i started the truck. after 1-2 minutes. the light went off. so i thought nothing of it.
this morning, start truck see light. head off to work. same- light went off a few minutes into drive. but something seemed weird. almost felt like the trans was not shifting as normal.
i stop and started several times- looking to feel trans shifting, but didn't seem to be acting correctly.
leaving work.
start truck- see abs light. pull out of my spot and usually from where i park to the stop sign, i can alway feel truck shift. no shift.
i make a right onto the main road- screaming- as if to be stuck in first -
couple hundred feet. i notice everything on dash- GOES DEAD- rpm- speed- every needle dropped to 0
then seemed to correct itself and from there to the house. truck seemed to shift fine.
i believe yesterday on the drive to work. i did notice the same dash play- momentarily, everything goes to 0
and then truck is fine????
any ideas?? and if i am posting in the wrong place. please let me know and i will move.
truck is a 97 tahoe- 4 door- 4x4- 96k
leaving work.
