Tranny help!! XD just need some info quick
JubjubW
Wausau, WI
Cracked the housing on my tranny . Gonna change it this weekend. Want to know how easy it is to drop a 4L80E in or if it's just easier to throw the 60 in quick without problems.
retorq
Kingman AZ
Depends on the year, later model years have replaceable bell housings if that is where it cracked.
omaha
When I cracked my transmission, I was planning on putting the 80 in. As long as you get one from the correct year everybody told me it would be fine, but they are harder to find and a little bit more pricy. At the last second I whimped out and put a 60 back in. How did you break yours?
JubjubW
JubjubW
Wausau, WI
It cracked right around the tail end before it mates to the transfer case. The entire tranny case is shot.
So far I've been looking and 60s are gonna run me a hell of a lot for high miles in my area. The bone yard that has the cheapest parts doesn't have any sadly. A guy I work with might have one out of a 95 pickup. Will that work?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Any 4l60e should work as long as you note that the later '99-on units had a slightly bigger converter and different bell housing. IIRC the flex-plate was changed because of it. It year from the factory improvements were made on the tranny so depending on what you get will determine if you have a better built one then before. You can always rebuild it and incorporate the changes as well. being a 95 it probably is not likely to have hardly any improvements in it.
omaha
This is what mine looked like after my drive shaft dropped doing about 90
JubjubW
JubjubW
Wausau, WI
Ouch.... Well I'm okay with a 95 right now. Need wheels. Was riding the bike since the snows melting. Then it got cold so I grabbed and put plates on my dads 73 Sprint.
omaha
What condition was the trans in? When mine cracked, I found a shop that had the case and he was going to charge me $100 for the case and $50 for putting it on. It turned out that mine didn't have much life left any ways so I ended up getting a rebuild.
retorq
Kingman AZ
Once again what's his face doesn't know what he's talking about, 95 is the last year you want, it was a 1 year only tranny. If you have a 95 then swap with a 95. If you have pre then use pre that's fine.
SunlitComet
OBS Jedi-Do Good
Oh and one other thing since I believe yours was a 4wd you should not have to worry about the speed sensor size difference as you will not be using the tail shaft like a 2wd unit does. And make sure the 1995 tranny you may get does not have a build year of 1994.
JubjubW
JubjubW
Wausau, WI
Will do.
Wow I didn't get any updates about this forum >.<
Not sure what the bone yards are looking at for year wise. What about going with something newer? Like after 2000? I'll make anything work if I can
JubjubW
JubjubW
Wausau, WI
Or there is a turbo 350 fresh rebuild. For a good price.
Just looking for options here. Dunno how much more life the truck has
retorq
Kingman AZ
If it is a long tail 350 it will bolt in and can be made to work. Just flash the ECM to a manual setup and row your own gears. :D
vtxtexan
