Towing with 33in tires
15momwagon
Waiting on my new wheels and tires to come in and it dawned on me.. I only have a 2in level installed on the front, nothing in the back. Will I still be able to tow with 33in tires or do I need to lift the rear to avoid rubbing? 2015 Tahoe.
Bill 1960
Testing the Limits
Your suspension is going to cycle and hit the bump stops occasionally towing or not. So the tires need to clear at full compression.
Dantheman1540
Sugar Loaf Mountain
If it does rub at full compression you can run a set of helper bags and fill them up till they are stiff enough that it limits up travel.
