Torque steer
Yukon50BMG
I have an 03 Yukon, recently replaced upper and lower control arms, shocks, tie rods, and rear springs. Leveled with Bilsteins and 33” bfgs. Recently went on an off-road excursion and developed pretty bad torque steer and slop in the steering. I can hear one of the tires squeal under acceleration on the pavement and it pulls to the left until it shifts then it straightens out. I have a ball joint seal on the passenger UCA that came apart from too much grease most likely, other than that everything else appears in order. Any ideas? Thanks
Bill 1960
Testing the Limits
Inspect all the steering and front suspension joints. Test with pressure using a crowbar. Could be anything in this group that’s moving and throwing out the alignment under torque.
dlpfcb
